running lights? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 05-22-2011, 01:11 AM Thread Starter
running lights?
i am a new owner of a 2008 aero, i noticed that the rear signal lights are not the same color, and that the front signal work as running lights as well as signals, however the rear lights only light up when the signal is engaged. i am thinkin that someone replaced one of the rear bulbs with a single filament. causing the lights not to function correctly... my question is are the lights supposed to function as running lights. i cant find anything about this in the owners manual.
scottslob is offline
post #2 of 8 (permalink) Old 05-22-2011, 02:06 AM
Your stock rear signal lights are only on when the turn signal is activated.The fronts are always on as a safety feature.
motorn is offline
post #3 of 8 (permalink) Old 05-22-2011, 04:52 AM
This.
Now post some pics of your ride, and not some tiny thumbnails either, or the natives will get restless.
Martin
Kingshead is offline
post #4 of 8 (permalink) Old 05-22-2011, 09:19 AM
That's the way they're intended to work (poor/cheap design, it seems to me). But there are kits you can buy/install to convert the rear lights so that they act as running lights too. And brake lights. I did that on my '06 Aero and it was easy to do (with the Kury kit).
06 Aero 750
hbark is offline
post #5 of 8 (permalink) Old 05-22-2011, 10:03 AM
oconeedan's Avatar
I was thinking about the DIY project here:
Rear Running Lights Mod Bareass Choppers Tech Pages
Anyone else done this using the recommended parts on their link, and how do you like it?
Half of my riding is at night.
Dan
2000 Shadow 1100 ACE Tourer
2007 Royal Star Tour Deluxe
oconeedan is offline
post #6 of 8 (permalink) Old 05-22-2011, 11:25 AM
You could get red lens covers and install a run-turn-brake kit
4710 - Kuryakyn Run-Turn-Brake Controller and Diode Kit
CTS-0020 - Clear Alternatives Clear Turn Signal Lenses for Honda Cruisers (pair)
I should have mine all fixed up that way in about 2 weeks.
bikeless !
2012 Kawa KLX250S (ret)
2006 Honda Shadow Sabre (ret)
2001 Kawa KX125 (ret)
1999 Suzuki SV650 (ret)
1987 Kawa GPZ 305 (ret)
marcham is offline
post #7 of 8 (permalink) Old 05-22-2011, 01:30 PM
i changed my rear to running /turn
i could have also made these 2 lights brake and turn instead
but i like the idea of more light for them silly cages to see
also installed the back-offxp brake light modulator - flashs 4 times stays on then repeats
i also changed the plate location and brake light location yet again hahaha
new pix of this soon
check my pix i added 2 of the new mounts brake light an plate
elfnyc is offline
post #8 of 8 (permalink) Old 05-22-2011, 04:55 PM
elfnyc is offline
