late 90,s shadow 1100 - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 05-08-2012, 11:37 AM Thread Starter
Post late 90,s shadow 1100
Found a nice one 2000$obo good and bad of this bike..... any major problems with 96-99 shadows?....btw 15,000 miles but looks great very clean
getLOW is offline
post #2 of 15 (permalink) Old 05-08-2012, 03:46 PM
I have the 95 VT1100C2. The only issue I had was battery acid corrosion near the battery vent tube passes through frame (bottom left of battery). I have more than 50k miles. Also check for fork seals (oil on forks). Basically you should be able to tell how well the bike was maintained by service records and general care.
G.
gdb069 is offline
post #3 of 15 (permalink) Old 05-08-2012, 06:27 PM Thread Starter
How much difference is there between a 96 model and a 2001 model?
getLOW is offline
post #4 of 15 (permalink) Old 05-08-2012, 06:34 PM
Spool's Avatar
Depends on which model 1100 you are looking at. For instance '96 was the last year the VT1100c had a four speed transmission. Starting in '97 it gained a 5 speed and became known as the Spirit 1100. The tank is slightly different and a few other minor changes but otherwise is the same bike.
If you tell us exactly which models of the 1100 you are looking at someone here will be able to point out the differences for you. Any of the 1100's are great bikes with nearly bulletproof reliability.
2002 Shadow Spirit 1100
Spool is offline
post #5 of 15 (permalink) Old 05-08-2012, 07:00 PM
All I can say is that I'm deleriously happy with my '99. FWIW, I paid $3200 for it w/6600 mi. on it.
rb608 is offline
post #6 of 15 (permalink) Old 05-08-2012, 07:38 PM Thread Starter
Its actually a 97 model its on yakaz.com search * shadow 1100 for sale alabama* its the one who's father owned it but passed away and the son is selling it
getLOW is offline
post #7 of 15 (permalink) Old 05-08-2012, 08:40 PM Thread Starter
Anyone with knowledge on the shadow 1100 of the late 90,s
getLOW is offline
post #8 of 15 (permalink) Old 05-08-2012, 10:53 PM Thread Starter
Btt
getLOW is offline
post #9 of 15 (permalink) Old 05-09-2012, 05:54 AM
xrayr's Avatar
Is it a single pin crank engine? If it's a single pin crank 1100 engine, it could have the guide plug leak issue. Do a serach on it. My old 1999 VT1100C3 had the guide plug leak issue...........
2008 Black Goldwing ABS
xrayr is offline
post #10 of 15 (permalink) Old 05-09-2012, 09:18 PM
BizTalk Rider's Avatar
I ride a 97 VT1100C2 ACE. I bought it used with 10,900 miles for aprox $2700. So far the only issue was corrosion in the battery cage as indicated by GDB069, but I replaced the entire cage from Ebay and purchased a sealed battery as well. This took care of the corrosion issue. Other than that, no problems to date. Very happy with my purchase!
When life throws you a curve...lean into it !
1997 VT 1100 C2 ACE
BizTalk Rider is offline
