Blinker Sticks - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-22-2012, 09:15 AM   #1 (permalink)
Default Blinker Sticks
In cold weather, the turn signal switch is harder to slide. There is also a delay in the lights to start flashing. Is there anything I can do to the switch to fix it? Have to replace it?
cgarcer is offline   Reply With Quote
Old 11-22-2012, 09:18 AM   #2 (permalink)
hiteck's Avatar
I sprayed inside of mine with electric contact cleaner and its a lot better. I plan on taking it apart and applying some dielectric grease on the contacts as it's still kinda stiff and hit or miss if it cancels or not.
hiteck is offline   Reply With Quote
Old 11-22-2012, 09:26 AM   #3 (permalink)
Thunder Johnson's Avatar
Default Switch Cleaning 101
Do a search for a thread titled "Switch Cleaning 101."
Thunder Johnson is offline   Reply With Quote
Old 11-22-2012, 09:30 AM   #4 (permalink)
Thank you.
Old 11-22-2012, 09:38 AM   #5 (permalink)
Super Moderator
old dad's Avatar
The thread "switch cleaning 101" has now been made as a "sticky" in the tech section.
2006 vlx
Old 11-23-2012, 04:21 PM   #6 (permalink)
seanie's Avatar
The switch sticking is directly related to the switch being gunked up. Give it a good cleaning and you shouldn't have a problem. As far as the delay in the blinkers, that's your relay. It's a little metal coil that expands and contracts. In cold weather, it takes longer until it's warmed up. The only fix for that is a digital relay.
seanie is offline   Reply With Quote
Old 11-24-2012, 08:33 AM   #7 (permalink)
While you at it you should clean the starter and run/stop switches on the other side. before you get stuck on the side of the road 100 mile from home. Take the switches apart for cleaning. Dielectric grease is a must, keeps the switches from corroding and clean, but it will harden when dirty. As for the slow start, thats do to the dirty grease, preventing contact in the switch. FWI, the relay is just a switch, also, the slowness there is also do to DIRT, not temperature.
Old 12-03-2012, 09:57 PM   #8 (permalink)
Cleaning worked. Thanks!
