about how many miles to a tank vlx 600 - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 10-05-2008, 04:02 AM Thread Starter
about how many miles should i get out of a full tank of gas on the 600? i try to hit the station at the 130mile trip point don't want the run out.
EXTREMEG is offline
post #2 of 12 (permalink) Old 10-05-2008, 04:06 AM
Take your Gallons and divide them into the miles, do this ten times to get a average and don't figure in the reserve then you'll know for sure and won't be guessing.
Ted
SHADOW 1100T is offline
post #3 of 12 (permalink) Old 10-05-2008, 04:08 AM Thread Starter
should the reserve be set to off for riding?
EXTREMEG is offline
post #4 of 12 (permalink) Old 10-05-2008, 04:52 AM
Yes, otherwise when you run out of gas you really are out of gas. The reason it took some time to restart the last time is that the shut off is vacuum controlled and will only let gas in when there is a vacuum so you have to hit the starter quite a bit, trick is is to NOT have to do that.
Ted
post #5 of 12 (permalink) Old 10-05-2008, 08:51 AM
Maggiethecat's Avatar
Send a message via MSN to Maggiethecat
I get appox. 100 without hitting reserve. But it depends on how hot I ride.
Totaled on 4/27/10
If you're going through Hell - keep going!
Sir Winston Churchill
2000 VLX600
I need MORE CHROME!
Maggiethecat is offline
post #6 of 12 (permalink) Old 10-05-2008, 10:24 AM
I average 120 to 130 miles before hitting the reserve.
MLR1 is offline
post #7 of 12 (permalink) Old 10-05-2008, 11:55 AM
Super Moderator
CleoBen's Avatar
NO!!!!!
On the VLX, the fuel selector knob has three settings: ON / OFF / RES
When OFF is facing up, there is no fuel flowing through the petcock, and the engine will not start or run.
You can run an entire tank through the petcock when in the reserve (RES) setting. Since the VLX only has a 2.9 gallon tank including the .9 gallon reserve, you need to know your average fuel mileage for your typical riding environments. Interstate speeds will reduce your mileage significantly compared to the lower speeds often found on the back roads.
For example, if you average 60 MPG, you can expect to travel no more than 174 miles (2.9*60) on a full tank of fuel. Of course that's in ideal conditions not real life. Way too many variations in actual riding conditions to plan on that distance. The most I ever got on ours was 168 miles from full tank to stranded-on-the-side-of-the-road-bone-dry.
Here's an easy way to plan fuel stops with the VLX: (Caution, it involves public math!!!)
1. Fill the tank and place the petcock switch to ON.
2. Zero out the odometer.
3. Ride your heart out!
4. When the engine starts to sputter, usually between 100 - 120 miles, switch to RES and note the odometer reading.
5. Divide the current odometer reading in half in your head.
6. Add your result to the current odometer reading, minus about 10 miles for cushion.
7. Get more fuel before that time!
This will help you figure out the max you can expect if nothing changes in your riding style and conditions. Obviously, start looking for a fuel stop when your comfort level dictates. On our VLX, about 2 1/2 hours buzzing along in the saddle was about the max we could stand anyway.
CB
CleoBen is offline
post #8 of 12 (permalink) Old 10-05-2008, 12:37 PM
Re: about how many miles to a tank vlx 600
94 VLX 600...57-60 mpg. Neighborhood at 35-40 and highway at 55-60. Only had it 3 mos...had 19,500 miles and Cobra Straight pipes...pops on deceleration. Drilled out the caps on the idle mix screws and have been backing out to improve poping.
Stock sprockets. Near 120 miles I get ready to go to Reserve.
One good note I saw was to move the key cover on the fuel cap when you switch to Reserve as a reminder.
I use 2 oz of Seafoam fairly often per full tank.
Charlie S - War Eagle!
06 VT 750 Shadow Spirit
94 VT 600C VLX (Donated to Sis-in-Law 4-23-10)
Concerned about gun control...use Both hands.
86 Suzuki Intruder 700
Landlrd2 is offline
post #9 of 12 (permalink) Old 10-05-2008, 01:28 PM Thread Starter
ok thanks i'm just trying to get my head around this 2.9 gallon tank. my sport bike had a 4gallon so it's throwing me off. thinking i'm stopping for gas so often.
EXTREMEG is offline
post #10 of 12 (permalink) Old 10-06-2008, 09:55 AM
highlandman's Avatar
I start looking for gas at 100 miles. I hit reserve consistently between 110-120, except on an extended (non-slab) cruise where my mileage is a little better.
I have never run it all the way out (yet). The farthest I ever took it was 150 miles, and it took 2.7 to fill it --- as close to walking as I want to get.
I ride on "ON" and switch when it sputters.
Like most people I am plenty ready to get off for a few minutes by the time the VLX needs a drink.
-Glenn
2002 VLX Deluxe
Ride bell by Lisa AND Kara
highlandman is offline
