Oil filter for 07 Aero - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 10-24-2008, 02:41 PM Thread Starter
I'm getting ready to change oil (using Rotella T) and filter. Been getting the filter in the past from the local Honda dealer - 13 bucks a pop.
I have seen some charts but have been unable to find a cross reference for another filter to fit the 07 Aero. The charts I seen didn't go up to 07. I would like to go with a Purolator One but a few stops that I made didn't carry the brand. I did notice that Wally carried the Fram motorcycle filter but didn't have a book to tell which filter to use, and I'm not wanting to use the Fram brand - I'll go across town and get a dealer filter just to keep from using a Fram. Another fella in there was buying one of their Super Tech filters for his bike. It was the ST6607 and he said he had good luck with it and it does fit several other bikes, but we didn't know about mine. He also said that Pep Boys may carry the Purolator One, so I may check on that later today or tomorrow. The Wally I went to didn't have a filter book.
I normally use Napa Gold filters for my vehicles but not sure if I want to find a usable one for the Aero.
So for now I'm on the Purolator One kick - anyone know which filter number will work for the 07 Aero? Appreciate any inputs
Gnuiser is offline
post #2 of 12 (permalink) Old 10-24-2008, 02:59 PM
For my 2006 Aero -- which is probably the same as 2007 but you may want to check with the dealer or whatever to verify -- it's the Purolator Pureone PL14610.
If you can't find them anywhere, they're on Amazon for 2 for $9.48. Plus shipping, but shipping is free if you get $25 combined worth of stuff.
http://www.amazon.com/Purolator-PL14...4870963&sr=8-1
06 Aero 750
hbark is offline
post #3 of 12 (permalink) Old 10-24-2008, 03:07 PM
Oil filter
WalMart SuperTech ST7317 oil filter has worked very good for me and several other people on this forum. $2.77 a piece, can't beat that price. Looks to be a relabeled Fram filter, for a third the price.
jpr1968 is offline
post #4 of 12 (permalink) Old 10-24-2008, 03:17 PM Thread Starter
I was just on the phone and one fella said he thinks (thinks worry me) that the PL14610, as you stated is the Purolator One filter number - thanks.
Gnuiser is offline
post #5 of 12 (permalink) Old 10-24-2008, 03:25 PM Thread Starter
Re: Oil filter
From what I'm finding, the ST6607 is the same as the ST 7317. The difference is that the ST7317 is 3/4" longer - also interesting is it has 33 pleats - the ST6607 has 43 (i think it was 43) pleats - and so do to this, the ST6607 only has something like 18% less media than the ST7317. The ST6607 specs:
2.49" Length
2.70" Diameter
M20x1.5 thread
11-17 psi relief valve
2.47" Gasket OD
2.20" Gasket ID
59 Sq. In. media area
Someone is telling me that that it is nearly the same specs as the factory filter - well these are some notes I wrote from some of the calls.
I think where I screwed up is I just notice I didn't run this post in the Tech section - sorry
Gnuiser is offline
post #6 of 12 (permalink) Old 10-24-2008, 05:49 PM Thread Starter
I'm going to try the ST6607 Super Tech
Trolling around, found a cut-away of the ST6607 & ST7317
http://groups.msn.com/gl1800/general...66675666844976
There is some interesting read to go along with it. Anyway I'll bike back over to Wally this evening to get the filter. If I would have known, I probably would have snatched one when I snatched up a gallon of the Rotella T 15w-40 this morning. I almost snatched the Rotella Synthetic instead, maybe come this spring I'll switch to the synthetic and give it a try.
Anyway I Google ST6607 and there was pages of hits regards to the 6607 & 7317.
Gnuiser is offline
post #7 of 12 (permalink) Old 10-24-2008, 09:13 PM
TLH101's Avatar
I use the Super Tech 7313, that allows me to use 3 full quarts of oil. I always check the filter inside the box to make sure it is "made in the USA". Apparantly the USA version has a better check valve.
Terry
'04 Aero 750
TLH101 is offline
post #8 of 12 (permalink) Old 10-25-2008, 10:05 AM
Oil filter
The number of pleats the filter has is not that relevent. You have to look at the amount of filter material and the st7317 has more media. That's why I use it.
jpr1968 is offline
post #9 of 12 (permalink) Old 10-25-2008, 11:37 AM
This is a list of motorcycles and ATVs and the filters they use. If the motorcycle has a reference next to it such as [5], then look in table section [5] at the bottom of this page for your options in oil filters.
If your bike does not use a spin-on oil filter, the given number is a Fram part number. The filter media from Fram will be of normal quality, and pretty much as good as you can get anywhere else. At the very bottom of this page there's a small cross- reference table relating a few Fram / WIX / Purolator import filters. This will give you a few more choices if your bike uses one of the CH6xxx numbers.
Most modern motorcycles use the filter I call type [5], so this is the filter where I give you the most options. Personally, I always use Purolator Pure One PL14610s, which, along with the Mobil-1 M1-110 is clearly the best oil filter available. A small step down are the Bosch and SuperTech filters. These filters all have advanced filter media which is clearly superior to anything else on the market. The SuperTech filters, at $2 each, are a real steal. The AMSOil filters also have the advanced media, but they only have a very few square inches of it. Because of my fear that these can become clogged up too easily, I cannot recommend them. The remaining filters all have "normal" media, and have significantly poorer performance in capturing particles. I recommend you avoid Fram and Pennzoil filters.
To learn more about oil filters, read All About Oil Filters. To see the innards of many of the filters listed below, see Filter Surgery. To learn more about engine oil, read All About Oil.
ARCTIC CAT
250 2x4, 250 4x4 1999-2002 CH6066 280 2x4, 280 4x4 1998 CH6066
300 2x4, 300 4x4 1999-2002 CH6066 371 2x4, 371 4x4 1998 [2]
375 2x4, 375 4x4 AUTOMATIC 2002 [2] 400 2x4, 400 4x4 1999-2002 [2]
454 2x4, 454 4x4 1998 [2] Bearcat 2x4, Bearcat 4x4 1996-1997 [2]
500 4x4, 500 4x4 AUTOMATIC 2000-2002 [2]
BMW
R45, R560 1969-1972 CH6061 R60 1969-1984 CH6061
R65 1978-1984 CH6061 R65 1985-1988 CH6060
R65 LS 1978-1985 CH6061 K75 1985-1992 [7]
R75 1969-1984 CH6061 F800 S, ST, GS 2006+ [7]
R80G, S, ST 1981-1984 CH6060 R80 1976-1984 CH6061
R80 G/S Paris-Dakar 1987-1990 CH6061 R80 G/S Paris-Dakar 1991 CH6062
R80 ST 1983 CH6060 R80 S 1981 CH6060
R80G 1981 CH6060 R100 RT 1976-1984 w/oil cooler CH6062
R100 R, RS, RT, PD 1986-1991 CH6062 R100 RT 1976-1984 w/o oil cooler CH6060
K1 1989-1993 [7] R100 S, T 1976-1984 CH6061
K100, LS, LT, RT 1983-1993 [7] K1100, LT, RS 1990-1993 [7]
R1100 R, RS, RT, S, GS 1993-2007 [7] R1150 R, RS, RT, GS 2000-2007 [7]
K1200 GT, LT, RS 1999-2007 [7] R1200 C, RT, GS, HP2 1999-2007 [7]
BUELL
Blast 2000-2007 PH4967 Firebolt XB9R 2003-2007 PH4967
Lightning XB9S 2003 PH4967 RR1000 1987-1988 [3]
Cyclone M2 1997-2002 [3] Lightning X1 1999-2007 [3]
Lightning S1 1996-1998 [3] RR1200, RS/RSS1200 1989-1993 [3]
Thunderbolt S3, S3T 1997-2001 [3] Thunderbolt S2, S2T 1995-1996 [3]
X1W White Lightning 2002 [3] XB12S Lightning [3]
DUCATI
620 Sport 2003-2006 [6] 748, 748R, 748S 1997-2003 [6]
800 Sport 2003 [6] 800SS 2003 [6]
907 IE 1992-1997 [6] 916 1994-1997 [6]
996, 996R, 996S 2000-2001 [6] 998 2002-2003 [6]
999 2003-2007 [6] MH900e 2001 [6]
Monster 1997-2007 [6] Paso 1986-1990 [6]
ST2 1998-2003 [6] ST4 1999-2007 [6]
Sport 2002 [6] Superbike 1990-1997 [6]
Supersport 1990-2002 [6] 1000SS, GT 2003-2007 [6]
HARLEY-DAVIDSON
XL Sportster 1984-2007 [3] KH, XLH Sportster 1954-1978 CH6067
FL, FLH 1953-1982 CH6067 FX (All Models) 1983-1987 [3]
FX (All Models) 1971-1982 CH6067 FXE,FXS,FXWG 1982-1986 [6]
Evo 80" 1984-1999 [3] 88" 1999-2006 [3]
96" 2007- [3] V-Rod (all years) [5]
HONDA
XR200R 1984-2001 CH6015 ATC250ES 1985-1987 CH6015
ATC250SX 1985-1987 CH6015 NX250 1988-1990 CH6015
TRX250 Recon 1997-2001 CH6015 Sportrax 250EX 2001 CH6015
TRX250X 1987-2000 CH6015 VTR250 Interceptor 1988-1990 CH6007
XL250R 1984-1987 CH6015 XR250L 1991-1996 CH6015
XR250R 1984-2007 CH6015 TRX300EX, FW 1988-2007 CH6015
ATC350X 1985-1986 CH6015 FourTrax 2000-2003 CH6015
XL350R 1984-1985 CH6015 XR350R 1983-1985 CH6015
CB350F 72-74 CH6008 CB400A Hondamatic 1978 CH6008
CB400F Super Sport 1989-1990 [5] CB400F Super Sport 1976-1977 CH6009
CB400T Hawk 1976-1981 CH6008 CM400A Hondamatic 1979-1981 CH6008
CM400C Custom 1981 CH6008 CM400E 1980-1981 CH6008
CM400T 1979-1981 CH6008 TRX400EX Sportrax 1995-2004 CH6015
Honda VF400 FD 1983 [1] XR400R 1996-2002 CH6015
CB450SC Nighthawk 1982-1986 CH6008 CB450T Hawk 1982 CH6008
CM450A Hondamatic 1982-1983 CH6008 CM450C Custom 1982 CH6008
CM450 1982-1983 CH6008 CMX450C 1986-1987 CH6008
TRX450S, TRX450XS 1998-1999 CH6015 S/ES 1998-2003 CH6015
CX500 1978-1982 CH6007 CB500K 1971-1973 CH6008
GL500 Silver Wing 1981-1982 CH6007 GB500 1988-1990 CH6007
VF500C Magna 1984-1985 [1] Rubicon 2001-2007 CH6007
VT500C Shadow, Ascot 1983-1986 [1] VF500F Interceptor 1984-1986 [1]
XR500R 1981-1984 CH6015 CB550 1974-1983 CH6009
CBR600F 1987-1990 [5] CBR600F2 1991-1994 [5]
CBR600F3 1995-1998 [5] CBR600F4 1999-2000 [5]
CBR600F4i 2001-2003 [5] VT600C Shadow VLX 1988-2003 [5]
XL600R 1983-1987 CH6015 XL600V Transalp 1989-1990 [5]
XR600R 1985-1998 CH6015 CB650 1979-1982 CH6009
CB650C Custom 1980-1981 CH6008 CB650SC Nighthawk 1982-1985 CH6008
CBR600F 87-02 [5] NT650 Hawk GT 1988-1991 [5]
CX650T Turbo 1983 CH6007 CX650C Custom 1983 CH6007
GL650I Silver Wing I 1983 CH6007 TRX650F Rincon 2003-2007 CH6007
NX650 1988-1989 CH6015 XR650R 2000-2007 CH6015
XR650L 1993-2007 CH6015 VF700C Magna, Sabre 1984-1987 [1]
CB700SC Nighthawk S 1984-1986 [1] VF700F 1984-1985 [1]
VF700C Interceptor 1984-1987 [1] VFR700F Interceptor 1986-1987 [1]
VT700C Shadow 1984-1987 [1] CB750A AUTOMATIC 76-78 CH6008
CB750F SUPER SPORT 1975-1982 CH6008 CB750K 1969-1982 CH6009
CB750 Nighthawk 1991-2007 [5] CB750 Nighthawk 1976-1983 CH6009
CB750C Custom 1980-1982 CH6009 CB750SC Nighthawk 1982-1983 CH6009
RVF750R, RC45 1994 [5] VF750 Magna 1994-2002 [5]
VF750C Magna, Deluxe 1988 [1] VF750C Magna, Deluxe 1982-1983 [1]
VF750C2 1997-1998 [5] VF750CD Magna Deluxe 1994-1996 [5]
VF750F Interceptor 1983-1986 [1] VF750S Sabre 1982-1983 [1]
VFR750F Interceptor 1990-1998 [5] VT750 Shadow 1983 [1]
VT750 Shadow 1992 [5] VT750 Shadow 1998-2003 [5]
PC800 Pacific Coast 1989-1998 [5] VFR800Fi Interceptor 1998-2007 [5]
VT800 Shadow 1988 [1]
CB900C Custom 1980-1982 CH6009 CB900F 919 2002-2007 [5]
CB900F Super Sport 1981-1982 CH6009 CBR900RR 1993-1999 [5]
CBR929RR 2000-2001 [5] CBR954RR 2002-2003 [5]
CB1000 1994-1997 [5] CB1000 Custom 1983 CH6009
CBR1000F 1987-1996 [5] GL1000 Goldwing 1976-1979 CH6009
RVT1000R RC51 2000-2005 [5] VF1000F Interceptor 1984-1986 [1]
VTR1000F Super Hawk 1998-2004 [5] CBX 1979-1982 CH6009
CB1100F Super Sport 1983 CH6009 CBR1100XX 1997-2003 [5]
GL1100 Goldwing 1980-1983 CH6009 GL1100A Gold Wing 1982-1983 CH6009
GL1100I Gldwng Inter 1980-1983 CH6009 ST1100 1991-2003 [5]
VF1100C Magna 1983-1986 [1] VF1100S Sabre 1984-1985 [1]
VT1100 Shadow 1989-2007 [5] VT1100C Shadow 1985-1988 [1]
VT1100 1995-2001 [5] GL1200 Goldwing 1984-1987 CH6009
ST1300, ST1300 ABS II 2003-2007 [5] VTX1300 2003-2007 [5]
GL1500 Goldwing 1988-2000 [5] GL1500C Valkyrie 1997-2002 [5]
GL1800 Gold Wing 2001-2007 [5] VTX1800 2002-2007 [5]
INDIAN
Chief 1999-2003 [3] Scout 2001-2003 [3]
Spirit 2001-2003 [3]
KAWASAKI
KLT200 1981-1984 CH6069 KLF220 Bayou 220 1988-2002 CH6070
EL250 Eliminator 1988-1993 CH6012 EX250 Ninja 1986-2007 CH6012
KL250, KLR250 1985-1999 CH6070 KL250 1978-1984 CH6069
KL250D KLR250 2000-2007 CH6070 KLF250 Bayou 2003-2006 CH6070
KLR250 1985-2005 CH6070 KLT250 1982-1985 CH6069
KLX250 1979-1980 CH6069 KSF250 Mojave 250 1987-2003 CH6070
KZ250, CSR, LTD 1980-1983 CH6069 KAF300 Mule 520, 550 2005 PH4967
KEF300 Lakota 1995-2000 CH6070 KLF300 Bayou 300,4x4 1986-2005 CH6070
EX305B1 GPZ 1983 19-0251 KZ305 CSR 81-82 19-0251
KZ305 CSR BELT 87-88 19-0251 KVF360 Prairie 360 4x4 2003 [5]
KLF400 Bayou 400 4x4 1993-1999 [5] KVF400 Prairie 400 4x4 1997-2002 [5]
KZ400 1974-1979 CH6012 KZ440 1980-1983 CH6012
EN450 454 LTD 1985-1990 [1] KAF450 1985-1991 PH4967
520 1998-2002 PH4967 550 1997 PH4967
EN500 Vulcan, LTD 1990-2007 [5] EX500 Ninja 1990-2007 [5]
EX500 Ninja 1987-1989 [1] KZ550 1980-1984 CH6012
ZR550 Zephyr 1990-1993 CH6012 ZX550 GPZ 1984-1986 CH6012
KL600 KLR 1984-1986 CH6070 ZL600 Eliminator 1996-1997 CH6012
ZL600 Eliminator 1986-1987 CH6012 ZX600 Ninja ZX-6, ZX-6R 1993-2007 [5]
ZX600 Ninja 600R 1985-1997 CH6012 ZX600, ZZR600 Ninja, ZX-6RR 2007 [5]
KAF620 Mule 1995-2003 PH4967 W650 2000-2001 [5]
KL650, KLR650 1987-2007 CH6070 CH6070
CH6070 CH6070
KLX650 1993-1996 CH6070 KLX650R 1993-1996 CH6070
KVF650 Prairie 650 2001-2004 [5] KZ650 CSR 1981-1983 CH6012
KZ650 LTD 1980 CH6012 KZ650 1977-1979 CH6012
KZ700 1984 CH6012 VN700 Vulcan 1985 [1]
ZN700 LTD 1984-1985 CH6012 ZX700R 1991-Present [5]
KZ750 LTD 1980-1983 CH6012 KZ750 1980-1983 CH6012
KZ750 SPECTRE 1982-1984 CH6012 KZ750 GPZ 1982 CH6012
KZ750 LTD 1976-1984 CH6014 KZ750 (2-CYL.) 76-84 CH6013
VN750 Vulcan 1994-2007 [5] VN750 Vulcan 1986-1993 [1]
ZR750 Zephyr 1991-1993 CH6012 ZR750 ZR-7 2000 CH6012
ZR750 ZR-7S 2001-2003 CH6012 ZX750 ZX-7, Ninja, ZX-7R 1991-2003 [5]
ZX750 Ninja, ZX-7 1987-1990 CH6012 ZX750 GPZ, A 1983-1985 CH6012
ZX750 GPZ750 Turbo 1984-1985 CH6012 ZX750-L, ZX-7, Ninja 1993-1995 [5]
ZX750 Ninja ZX-7RR 1996-1997 [5] ZX750-P Ninja ZX-7R 1996-1999 [5]
VN800 Vulcan 800 1995-2007 [5] KZ900 1976-1977 CH6013
Z-1 1973-1975 CH6013 ZL900 Eliminator 1985-1986 CH6012
ZX900 Ninja ZX-9R 1998-2003 [5] ZX900 Ninja 1984-1986 CH6012
KAF950 Mule 2510 Diesel 2000-2003 PH4967, [5] KZ1000 Police 1981-2001 CH6012
KZ1000 1977-1980 CH6013 ZG1000 Concours 1986-2007 CH6012
Z1000 2003-2007 [5]
ZL1000 Eliminator 1987 CH6012 ZX1000 Ninja ZX-10 1986-1990 CH6012
ZX 10R 2004-2007 [5] ZX1000 Ninja ZX-10 1986-1990 CH6012
KZ1100 1981-1983 CH6012 ZN1100 LTD 1984-1985 CH6012
ZR1100 2000 CH6012 ZX1100 ZX-11 Ninja 1990-2003 CH6012
ZX1100 GPZ 1983-1984 CH6012 ZXR1100 2000 CH6012
ZG1200 Voyager XII 1986-2003 CH6012 ZR1200 ZZ-R1200 2003-2007 CH6012
ZR1200 ZRX1200R 2001-2003 CH6012 ZX1200 ZX-12R 2000-2003 [5]
ZX1200 ZZR1200 2002-2007 CH6012 KZ1300 Touring 1979-1982 CH6013, CH6014
ZN1300 VOYAGER 83-87 CH6013 VN1500 Vulcan 88 1987-2003 [5]
VN1500 Vulcan Drifter 1999 [5] VN1500 Classic 1996-1997 [5]
VN1600 Vulcan 2004-2007 [5] Mean Streak 1600 [5]
VN2000 Vulcan 2005-2007 [5]
MOTO-GUZZI
California, Stone, EV [3] Special 2002 [3]
Special, Jackel 2000-2001 [3] California IE 1994-1999 [3]
V11 EV 2001 [3] V11 EV 1998-1999 [3]
Quota 1100ES 2000-2001 [3] V11 Sport 1998-2001 [3]
Sport 1100 1994-1997 [3] V11 Sport, V11 Le Mans 2002-2004 [3]
V11 Sport 2001 [3] V11 Bassa, Jackal, Quota, Sport 2000 [3]
POLARIS
Magnum 325 4x4, 2x4 2000-2002 [5] Trail Boss 325 2000-2002 [5]
Xpedition 325 2000-2002 [5] Magnum 330 2x4, 4x4, Trail Boss [5]
Sportsman 335, Worker 335 1999 - 2000 [5] Sportsman 400 2001-2003 [5]
Xpedition 425 2000-2002 [5] 425 Magnum 2x4 1995-1998 [5]
425 Magnum 4x4 1996-1998 [5] 425 Magnum 6x6 1996-1997 [5]
455 Diesel 4x4 1999-2001 [5] Sportsman 500, 6x6 1997-2003 [5]
Big Boss 500 6x6 1998-1999 [5] Magnum 500 1999-2002 [5]
Scrambler 500 1997-2003 [5] Xplorer 500 1997 [5]
SUZUKI
DR-Z125 2003 CH6066 DR125 1986-1988 CH6064, CH6066
DR125SE 1994-1996 CH6064, CH6066 SP125 1986-1988 CH6064, CH6066
LT-160K 2003 CH6066 LT-F160 2001 CH6066
LT-160E 1989-1992 CH6066 LT-F160E 1991-2000 CH6066
DR200 1986-1988 CH6064, CH6066 DR200SE 1996-2003 CH6064, CH6066
SP200 1986-1988 CH6064, CH6066 LT-230 1985-1993 CH6064, CH6066
LT-250 LT-F250 1985-2002 CH6064, CH6066 GN250Z/D 82-83 19-0249
GN250F 1985 19-0249 GN250J 1988 19-0249
GZ250X/Y/K1/K2 99-02 19-0249 DR250Z/D 82-83 19-0249
DR250F 1985 19-0249 DR250 90-95 19-0249
SP250Z/D DUAL SPORT 82-83 19-0249 SP250F DUAL SPORT 1985 19-0249
DR350 90-99 19-0249 GS250 1980-1981 CH6000
LT-4WD Quadrunner 1987-1997 CH6066 LT-F4WD 1987-1998 CH6064, CH6066
LT-F4WDX King Quad 1991-1998 CH6066 GS300 1985 CH6000
GS300 1982-1983 CH6000 LT-300E 1987-1989 CH6064, CH6066
LT-F300F 1999-2002 CH6064, CH6066 AN400 Burgman 2003 CH6066
GS400 1977-1978 CH6000 GSF400 Bandit 1991-1993 CH6000
LT-F400 Eiger 2002-2003 [2] GS425 1979 CH6000
GS450 1980-1988 CH6000 GS500E 1989-2000 CH6000
GS500K 2001-2002 CH6000 Vinson 2002-2003 [2]
Quad Master 2000-2001 [2] Quadrunner 2000-2003 [2]
LT-F500F 1998-2003 [2] DR500 81-83 19-6178
SP500 81-83 19-6178 GS550 1977-1986 CH6000
SP600F 1984 19-6178 GSF600S Bandit 1996-2003 [2]
GSX-R600 1997-2003 [2] GSX-R600W 1992-1993 [2]
GS650MD KATANA CH6000 GSX600F Katana 1988-2002 [2]
RF600R 1994-1996 [2] AN650 Burgman 2003 [2]
GR650 1983 CH6000 GS650 1981-1983 CH6000
SV650, DL650 1999-2003 [2] DR650S 90-02 19-6178
LS650 SAVAGE 86-88 19-6178 LS650 SAVAGE 95-02 19-6178
XN85 1985 CH6000 GS700 1985 CH6000
GV700 Madura 1985 [4] VS700 Intruder 1987 [2]
VS700 Intruder 1986 [4] GS750 1983 CH6000
GS750 1980-1983 CH6001 GS750 1977-1979 CH6000
GS750SD KATANA 1983 CH6001 GSX-R750 1996-2003 [2]
GSX-R750 1988-1992 [2] GSX-R750 1986-1987 [4]
GSX-R750W 1993-1995 [2] GSX750F Katana 1989-2003 [2]
VS750 Intruder 1988-1991 [2] VL800 Intruder 2001-2003 [2]
VS800GL Intruder 1998-2003 [2] VS800GL Intruder 1992-1996 [2]
VX800 1990-1993 [2] VZ800 Marauder 1997-2003 [2]
GS850 1979-1983 CH6000 RF900R 1994-1997 [2]
V-Strom 1000 2002-2003 [2] GS1000 1982 CH6001
GS1000 1978-1981 CH6000 GSX-R1000 2001-2003 [2]
GSX-R1000W 1993-1995 [2] SV1000 2003 [2]
TL1000R 1998-2003 [2] TL1000S 1997-2000 [2]
GS1100 1984 CH6000 GS1100 1981-1983 CH6000, CH6001
GS1100 1980 CH6001 GS1100S 1983 CH6000, CH6001
GSX-R1100 1986-1992 [2] GSX-R1100W 1993-1998 [2]
GSX1100F Katana 1988-1993 [2] GSX1100G 1991-1993 [2]
GS1150 1983-1986 CH6001 GSF1200S Bandit 1996-2003 [2]
GV1200 Madura 1985-1986 [4] GSX1300R Hayabusa 1999-2003 [2]
GV1400 Cavalcade 1987-1988 [2] GV1400 Cavalcade 1985-1986 [4]
VS1400GL Intruder 1987-1995 [2] VS1400GLP Intruder 1996-2000 [2]
VL1500 Intruder LC 1998-2003 [2]
TRIUMPH
Adventurer 1996-2001 CH6012 Bonneville 2001-2002 [5]
Daytona 1995-1997 CH6012 Daytona 955i 2000-2002 [5]
Daytona Super III 1995-1997 CH6012 Legend TT 1999-2001 CH6012
Speed Four 2002 [5] Speed Triple 1997-2002 [5]
Speed Triple 1995-1996 CH6012 Sprint 1995-1997 CH6012
Sprint RS 2000-2002 [5] Sprint Sport Tour 1999-2003 [5]
TT600 2000-2002 [5] Thunderbird 1995-2002 CH6012
Tiger 1995-1997 CH6012 Tiger 200--2003 [5]
Trident 750, Trident 900 1995-1997 CH6012 Trophy 1200 1998-2002 CH6012
Trophy 1995-1997 CH6012
VICTORY
V92C, V92SC 1998-2003 [5]
YAMAHA
XC180 1983-1985 CH6005 SR185 1981-1982 CH6005
C200, XC200T, XC200TC 1987-1991 CH6005 XC200U 1988 CH6005
XT125 1982-1983 CH6005 BW200 1985-1988 CH6005
TW200 TRAILWAY 1987-2000 CH6005 XT200 1982-1983 CH6005
YFM200 MOTO-4 1985-1989 CH6005 YTM200 TRI-MOTO 1983-1985 CH6005
TT225 1986-1987 CH6005 TT225 1999-2002 CH6005
XT225 SERROW 1992-2002 CH6005 YFM225 MOTO-4 1983-1988 CH6005
YTM225 TRI-MOTO 1983-1986 CH6005 YF230 PRO HAULER 1989 CH6005
SR250 Exciter 1980-1982 CH6005 SRX250 1987 CH6005
TT250 1980-1982 CH6005 XT250 Dual Purpose 1980-1984 CH6005
XV250 Virago, Rt 66 1988-2000 CH6005 YFB250 TIMBERWOLF 1992-2000 CH6005
YFM250 MOTO-4 1989-12991 CH6005 YFM250 BEAR TRACKER 2WD 2000 CH6005
YFM250 1999 CH6005 TT250 1999 CH6005
TTR250 2001-2002 CH6005 YZ250 2001-2002 CH6005
TT350 1986-1987 CH6005 XT350 1985-2000 CH6005
BW350 Big Wheel 1987-1988 CH6005 TT350T 1987 CH6005
XT350T 1987 CH6005 YFM350XT Warrior 1987-2003 CH6005
YFM350 MOTO-4, Big Bear, Wolverine 1987-2003 CH6005 YFP350 Terrapro 1987-1988 CH6005
XS360 1976-1977 CH6003 FZR400 R 1990 CH6003
FZR400 R 1988 CH6003 XC400 Kodiak 2000-2001 [5]
XS400 Maxim, Seca 1977-1983 CH6003 YFM400 KODIAK 1993-1999 CH6005
YFM400FA Kodiak Automatic, 4x4 2000-2003 [5] WR400 1998-2000 CH6005
YZ400 1998-1999 CH6005 YZ426 2000-2002 CH6005
YFM45FA Kodiak 450 4x4 2003 [5] SR500 1978-1981 CH6005
TT500 1976-1981 CH6005 XT500 1976-1981 CH6005
XV500 Virago 1983 CH6005 XT500 DUAL SPORT 1976-1981 CH6004
SR500 1978-1981 CH6004 TT500 OFFROAD 1976-1981 CH6004
XV535 VIRAGO 87-99 CH6005 XJ550 Maxim, Seca 1981-1983 CH6003
XT550 1982-1983 CH6005 XV550 Vision 1982-1983 CH6005
XT600 DUAL SPORT 1984-1995 CH6004 TT600 1983-1986 CH6004
SRX600S/SC 1986 CH6004 XVS650AK/AKC V-STAR CLASSIC 1998 CH6004
XVS650 V-STAR 1999-2001 CH6004 FJ600 1984-1985 CH6003
FZ600 1986-1988 CH6003 FZR600 1991-1999 [5]
FZR600 1989-1990 CH6003 SRX600 1986 CH6005
TT600 1983-1986 CH6005 XJ600 Seca II 1992-1998 [5]
XT600 1984-1995 CH6005 YFM600 Grizzly 1998-2001 CH6004
YX600 Radian 1986-1990 CH6003 YZF-R6 1999-2003 [5]
YZF600 1994-2003 [5] XVS650 V-Star 1999-2003 CH6004
XJ650 Maxim 1982-1983 CH6003 XJ650 Maxim Midnight 1981 CH6003
XJ650 Maxim 1980 CH6003 XJ650LJ/LK Seca Turbo 1982-83 CH6003
XJ650RJ Seca 1982 CH6003 YFM660F Grizzly 4x4 2002-2003 [5]
YFM660 RAPTOR 2001-2002 [5] FZ700 1987 CH6006
FZX700 Fazer 1986-1987 CH6006 XV700 Virago 1984-1987 CH6004
XJ700 Maxim 1985-1986 CH6003 FZ750 Genesis 1985-1988 CH6006
FZR750 1987-1988 CH6006 Maxim 1983 CH6003
XJ750 Maxim, Seca 1982 CH6003 XJ750 Seca 1981-1983 CH6003
XS750 1977-1979 CH6002 XV750 Virago 1981-1998 CH6004
YZF750 1994-1998 [5] YZF750RK/RKC 1998 [5]
TDM850 1992-1993 CH6005 XS850 1980-1981 CH6002
XJ900 Seca 1983 CH6003 XV920 Virago 1981-1983 CH6004
Midnght 1983 CH6004 XV920 Virago 1981-1982 CH6004
FZR1000 1991-1995 [5] FZR1000 1987-1990 CH6006
FZR1000 FZ1 2001-2003 [5] GTS1000 1993-1994 [5]
XV1000 Virago 1984-1985 CH6004 YZF-R1 1999-2003 [5]
YZF1000 1997-1998 [5] FJ1100 1984-1985 CH6006
XJ1100 Maxim 1982 CH6002 XS1100 1978-1981 CH6002
XV1100 1999-2000 CH6004 XV1100 Virago 1986-1998 CH6004
XVS11 V-Star 1999-2003 CH6004 FJ1200 1986-1993 CH6006
VMX12 V-Max 1996-2003 [5] VMX12 V-Max 1985-1995 CH6002
XVZ12 Venture, Royal 1983-1985 CH6002 FJR1300 [5]
XVZ13 Royal Star 1986-1993 CH6002 XVZ13 Royal Star 1996-2003 [5]
XV16A Road Star 1999-2003 [5]
Spin On Oil Filters
[1] These Oil Filters
have 20 x 1.5mm threads,
10-18 psi by-pass valve,
anti-drain back valve.
Recommended filters in blue. Available filters include:
Purolator PL14459
Mobil-1 M1-104
Supertech ST3593a
AMSOil SMF 102
Baldwin B227
Fram PH6010A
Hastings LF402
NAPA 1334
Purolator L14459
WIX 51334
[2] These Oil Filters
have 20 x 1mm threads,
11 psi by-pass valve,
None are recommended.
This is a proprietary Suzuki
thread, and no high performance
filters are made for 20mmx1mm
threads. Available filters include:
AMSOil SMF 109
Bike Master 314-0025
Champion PH7016
Cycle Power 314-1919
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Hi-Flo HF138
J.C.Whitney ZX063166P
K&N 138
NAPA 1359 / WIX 51359
Parts Unlimited
Per-Form J-509
ProPart 01-0029
Purolator ML16818
STP SMO-18
Suzuki 16510-03G00-X07
VESRAH vsf-3009
[3] These Oil Filters
have 3/4" x 16tpi threads,
Purolator PL10241 / PL25230
Mobil1 M1-102
Bosch 3330
AMSOil SMF 133/134/135
Baldwin B1413
Fram PH6022, PH6065A
Hastings LF576
NAPA 1348
Purolator ML16822
WIX 51348
[4] These Oil Filters
Mobil1 M1-102
Bosch 3330
AMSOil SMF 108
Baldwin BT223
Fram PH6016
Hastings LF157 / LF134
K&N KN-174C
NAPA 1348
Purolator L10241 / L20064
WIX 51348
[5]
These Oil Filters
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Buy these filters Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Automobile Filters,
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
[6] These Oil Filters
have 16 x 1.5mm threads,
None are recommended. Available filters include
AMSOil SMF 132/132C
EMGO 10-26980
Fram PH6019, PH6074
K&N KN-153
NAPA 7013
WIX 57013
[7] These Oil Filters
?? psi by-pass valve,
Mobil1 M1-102
Bosch 3330
Supertech ST3614
AMSOil SMF 122
EMGO 10-26740
Fram PH6063
Purolator ML16825
Cartridge type oil filters
For cartridge type filters, also see J.C.Whitney Fram WIX Purolator Height OD ID
CH6000 24931 ML16800 2.535 2.830 0.760*
CH6001 24932 ML16801 2.535 2.830 0.760*
CH6002 24933 ML16802 1.583 3.957 0.772
CH6003 24934 ML16803 1.441 2.996 0.768
CH6004 24935 ML16804 2.252 2.170 0.787*
CH6005 24936 ML16805 2.252 2.170 0.787
CH6006 24937 ML16806 2.260 3.050 0.770
CH6007 24938 ML16807 1.776 2.705 0.776
CH6008 24939 ML16808 1.860 2.750 0.770
CH6009 24940 ML16809 2.205 3.028 0.776
CH6012 24941 ML16812 2.205 3.028 0.772
CH6013 24942 ML16813 3.209 3.150 0.768
CH6014 24943 ML16814 3.209 3.150 0.768*
CH6015 24944 ML16815 1.484 1.965 0.460*
CH6060 24945 ML16827 2.303 1.634 0.575
CH6061 24946 ML36811 4.705 1.634 0.575
CH6062 24947 ML16826 2.575 1.634 0.571
CH6064 24949 ML16820 2.177 1.732 0.532*
CH6066 24949 ML16821 2.177 1.732 0.532*
CH6067 ML16828
CH6069 24950 ML16823 2.150 2.173 0.535
CH6070 24951 ML16824 2.150 2.173 0.535
* closed at one end, includes bypass valve.
hawkeze is offline
post #10 of 12 (permalink) Old 10-25-2008, 01:58 PM
Re: Oil filter for 07 Aero
Hubby and I use thePurolator Pureone PL14610 also on our 2005 and 2006 Aero. We purchased ours from a Farm and Fleet Store. Check out the rebate coupon and dealer locator. http://www.pureoil.com/. The coupon is expired but they offer different dates of promotion occasionally.
2005 Shadow Aero 750
Lora is offline
