whitewall tires - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 13 (permalink) Old 12-17-2009, 04:16 PM Thread Starter
whitewall tires
Ok, i don't post much so don't flame me.......just looking to help my son out. Has anyone found a wide white wall tire that'll work on the front of an 03 ACE. OEM tire is 120/90-17? Thanks for your help.
Dennis Adams is offline
post #2 of 13 (permalink) Old 12-17-2009, 05:43 PM
The only WWW tire for the front of my bike is made by Dunlop. Metzler makes them for the rear but not front.
1996 VT1100C2 ACE
rickbb is offline
post #3 of 13 (permalink) Old 12-17-2009, 06:46 PM
coffeeshadow's Avatar
I was randomly searching WWWs the other day for another project and ran across a site that shows how to sand the sidewall down on narrow whitewalls or white letter tires to make wide white walls because the white wall is usually wider than what shows. Probably not much help as I don't think they make narrow white walls for motorcycles (do they?). Will try to refind that sight and post a link.
Here is a link to a video, couldn't find the other sight.
http://www.youtube.com/watch?v=xkcm3rh60p0
Don't know that I would do it, though.
coffeeshadow is offline
post #4 of 13 (permalink) Old 12-18-2009, 02:38 PM
Not made. I had to use a 1.5" brush and a can of sneeker white for mine.
Actually have Dunlops on mine. Front and rear are not the same model but can't remember off the top of my head what they are. I'll look tonight along with the size.
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline
post #5 of 13 (permalink) Old 12-18-2009, 02:43 PM
rat
Kenda makes www tires.
Not sure if the size is right though.
Later, folks.
rat is offline
post #6 of 13 (permalink) Old 12-18-2009, 02:47 PM
Here ya-go. Found it in an old thread.
Front: Dunlop
Model: D404
140/80-17 69H
Rear: Dunlop
Model: K555
170/80-15 M/C 77H
The 120/90-17 front is the original size on my Aero also. The 140/80-17 fit without a problem.
2005 Aero
1974 XL100
post #7 of 13 (permalink) Old 12-18-2009, 02:49 PM
02ACESarge's Avatar
Send a message via Yahoo to 02ACESarge Send a message via Skype™ to 02ACESarge
http://750ace.com/forum/viewtopic.ph...ighlight=tires Check this out these guys know all about the 750 ACE.
02ACESarge is offline
post #8 of 13 (permalink) Old 12-18-2009, 03:52 PM
tono_raho's Avatar
whoa! boy! no need to run off to other sites for the answers...
You'll see in threads what some of us "Ace" riders have done. You just go with the Dunlop that is just a tad lower and wider. Check the threads for the size. But in some cases there will be a very slight rub that occurs in which you'll have touch the metal fender bracket with a angle grinder to rid you of any rubbing. Piece of cake and they look great!
'01 Honda Shadow 750 ACE
Mods so far- Front/Rear lowered; Whitewalls; lightbar; Exhaust mod; rear sproket swap and heavy clutch springs.
Live and Ride by:
"I may not know what the future holds.... but I know who holds the future"
tono_raho is offline
post #9 of 13 (permalink) Old 12-18-2009, 09:22 PM
Super Moderator
Phil's Avatar
Re: whitewall tires
Basically you're going to use a front tire for the 1100 Aero.
The 750ACE front tire is a 120/90-17 while the 1100 Aero front tire is a 140/80-17.
The Aero tire is a bit wider and has a slightly lower profile than the 750ACE tire. You might have to deal with some minor clearance issues because the Aero tire is slightly wider.
Good luck,
Phil
1973 Yamaha RD-350
Sterling Heights, Michigan
Phil is offline
post #10 of 13 (permalink) Old 12-20-2009, 06:23 AM
Blueblood's Avatar
Originally Posted by tono_raho
...You just go with the Dunlop that is just a tad lower and wider. Check the threads for the size. But in some cases there will be a very slight rub that occurs in which you'll have touch the metal fender bracket with a angle grinder to rid you of any rubbing. Piece of cake and they look great!
+1!
Blueblood is offline
