Aftermarket handlebar question - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-05-2012, 10:18 AM   #1 (permalink)
Default Aftermarket handlebar question
Wanted to find out what others do when they installed aftermarket bars. The switch houses on either side have a tab the fits in a hole on the oem bars. Are you guys grinding that tab off or drilling a hole in your new bars. I ground the tab off on my last project but wasn't sure if that was the common approach.
deadshadow is offline   Reply With Quote
Old 11-05-2012, 10:24 AM   #2 (permalink)
Either drill a hole or dimple the handlebars where the housing goes with a punch.
jpr1968 is offline   Reply With Quote
Old 11-05-2012, 10:43 AM   #3 (permalink)
hypostang's Avatar
I drilled a hole
1990 VT1100C
hypostang is offline   Reply With Quote
Old 11-05-2012, 11:38 AM   #4 (permalink)
MikeB's Avatar
I have ground off the tabs on several bikes when changing to aftermarket bars. The switch housings fit tight enough that they don't need that locating tab/hole. If for some reason they don't just put a wrap of electrical tape under there.
MikeB is offline   Reply With Quote
Old 11-05-2012, 01:42 PM   #5 (permalink)
Grinding off the tabs seem easier and that's what I've done but I'm gonna be doing it for a 3rd time I thought it would be good to see how others handle it. Thx
