Helmet noise - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-25-2012, 01:49 PM   #11 (permalink)
Theja1's Avatar
Originally Posted by trabb47 View Post
I would guess 1/2 or 3/4 helmets would be even noisier. Never tried either, always had FF.
Actually, the noisiest helmet I have is the FF. My 3/4 and 1/2 are much quieter. The 1/2 being the best. The FF seems like it amplifies my exhaust.
Just Ride....
Theja1 is offline   Reply With Quote
Old 12-25-2012, 02:20 PM   #12 (permalink)
Menhir's Avatar
Originally Posted by MikeB View Post
...The best solution is to wear earplugs.
Agreed. You can spend/waste a lot of money on helmets that may or may not solve your problem when a set of good earplugs will do the trick.
I rarely use them for local riding, but I almost always use them when I know I'm going to be on the superslabs. Besides reducing the wind noise, a quieter ride seems to reduce fatigue on long stretches, too.
I have a pair of cheap-o disposable foam earplugs in my saddlebags in case I lose or forget the good ones. For the good ones, I've been using Etymotic ETY's. Etymotic Research, Inc. - ETY-Plugs ER20 High Fidelity Earplugs which work fine, plus they,re easily cleanable and affordable.
They look like the ends would stick out too much for a helmet, but they don't get in the way at all. Plus, they don't muffle and block out sounds you may want to hear...they just turn down the volume. It took very little time to get used to them.
2005 Shadow VLX 600
Menhir is offline   Reply With Quote
Old 12-25-2012, 02:21 PM   #13 (permalink)
MikeB's Avatar
My full face HJC is noisy as well. It's almost unbearable without earplugs on long rides. It's just something about the way the helmet amplifies the wind noise. My Licks NOVDOT is MUCH quieter and it's an open face 3/4 helmet.
Yes, a 3/4 helmet will always be quieter than a FF because of the reason I mentioned before. It's at the point where the edges of faceshield meet the helmet where the noise is generated. OTOH, if your lower face ever meets the pavement I'm sure it will make a truly horrible noise.
Come to think of it, so will you.
MikeB is offline   Reply With Quote
Old 12-25-2012, 02:25 PM   #14 (permalink)
CrazyDave's Avatar
no I can think of a better one
Facebook page
CrazyDave is offline   Reply With Quote
Old 12-25-2012, 03:00 PM   #15 (permalink)
randyd's Avatar
My Shoei full face is very noisy. It's the only one I've worn so I can't compare it to others.
Interestingly, I find that the wind noise on mine comes from the rim at the back of the helmet. If I stuff something into the space between the back of my neck and the back rim of the helmet, the noise disappears almost completely.
I haven't found a practical way to do this for more than a few minutes at a time, but I'm working on it.
randyd is offline   Reply With Quote
Old 12-25-2012, 03:10 PM   #16 (permalink)
Big B's Avatar
I have an HJC full face which is very comfortable but at highway speed the wind noise is awful. Can anyone recommend a more quiet helmet.
Thanks and Merry Christmas to all.
My HJC is the same way. Except for that, I love the helmet. My Shoei RF1000 is much quieter, but not as comfy.
Bernie
08 M109R *SLAMMED*
02 Sabre, gone but not forgotten
Big B is online now   Reply With Quote
Old 12-25-2012, 03:26 PM   #17 (permalink)
rjdaines's Avatar
Make sure the screws on the visor mechanism are tight on the HJC. Mine loosened up over time and made the helmet very noisy.
Honda Shadow VT750 Aero (2012)
rjdaines is offline   Reply With Quote
Old 12-25-2012, 09:07 PM   #18 (permalink)
Redman52's Avatar
One choice would be a 469 dollar helmet.
or
69 cents earplugs.
I choose the latter.
86 VT500C since 2004.
http://www.hondashadow.net/forum/viewtopic.php?t=84090
Have had Suzuki GSs for 20+ years
Redman52 is offline   Reply With Quote
