How does a leaky exhaust cause a bike to run poorly? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-06-2008, 10:57 AM   #1 (permalink)
Shandley's Avatar
Default How does a leaky exhaust cause a bike to run poorly?
Just curious, how does an exhaust leak lead to poor running. It seems to me when you have more back pressure, you keep the exhaust out of the combustion chamber more. Since the valves are run on a cam, I don't see this back pressure keeping the bike from pulling the intake valve open or anything like that. To me, that's where it ends. Can anyone out there help me out with this?
Thanks,
Shandley.
2004 Honda Shadow Aero VT750C: Punched exhaust.
2005 Honda VTX 1300S: DG Hardchrome, American Classic straight pipes, Backrest, Barons tach, Cobra Light Bar, Triple Whammy lamps, Cobra Passenger & Front Floorboards, K&N air filter, Willie & Max saddlebags, Mustang wide saddle touring seat
Shandley is offline   Reply With Quote
Old 10-06-2008, 12:16 PM   #2 (permalink)
DK
DK's Avatar
I'm no expert on this, but I do know that there is a period during which both the intake AND the exaust valves are partially open at the same time. It is called valve overlap and it is designed into the cam. The idea is to let the shockwave from the exhaust leaving to create additional vacuum for the intake mixture.
If there is a mechanic out there, can you please weigh in on this?
DK
1998 Honda Shadow ACE 750
Remember, riding isn't inherently dangerous...
crashing is.
DK is offline   Reply With Quote
Old 10-06-2008, 01:08 PM   #3 (permalink)
Having an exhaust leak in a two cylinder engine will cause one cylinder to create more power than the other cylinder, this can either make the leaking cylinder create more or less power (depending on a number of factors) but what you want is both cylinders to be balanced or you end up with vibration and other problems.
What exactly is the problem you are having?
landon is offline   Reply With Quote
Old 10-06-2008, 01:19 PM   #4 (permalink)
xrayr's Avatar
All I know is that when my exhaust gasket failed, I had some bad popping from where it attached to the engine. I didn't ask why, I just hurried to fix that thing!
2008 Black Goldwing ABS
xrayr is offline   Reply With Quote
Old 10-06-2008, 01:41 PM   #5 (permalink)
Oh that, heat + air + unburned fuel = bang.
Old 10-06-2008, 01:49 PM   #6 (permalink)
Default Leaky exhuast
It leans out the cylinder that has the leak and that imbalance is not good.
jpr1968 is offline   Reply With Quote
Old 10-06-2008, 02:02 PM   #7 (permalink)
Shandley's Avatar
Default Re: Leaky exhuast
So if it is a single cylinder engine, it wont matter if there is a leak or not?
I guess another question would be, why do we need to re-jet the carb when we put on a higher flow exhaust?
Thanks,
Shandley.
Old 10-06-2008, 09:23 PM   #8 (permalink)
To really find out if an exhaust leak is causing a loss of horsepower you would need hook the engine up to diagnostic equipment and find out where the peak torque and horsepower occur then try different widths and lengths of exhaust pipes to find out where the engine is happy and where it is not. It may like more back pressure or it may be unhappy and wishes that you would let it breathe where in that case it may actually run better with an exhaust leak.
Old 10-06-2008, 09:57 PM   #9 (permalink)
Generally, for optimal performance, the air/fuel mixture is often approximately 14.7 times the mass of air to fuel. If your bike is running well and then develops an exhaust leak, it will most likely allow more air flow without necessarily more gas, and it will run lean and get less performance. The following may help explain:
http://en.wikipedia.org/wiki/Air-fuel_ratio
Rejetting a carb involves, generally, increasing the amount of fuel going to mix with the increased amount of air that a more free flowing aftermarket exhaust allows.
Riding for the Son.
2003 Spirit 1100, 2006 Suzuki GS500F
ShadowDave is offline   Reply With Quote
Old 10-07-2008, 11:10 AM   #10 (permalink)
Shandley's Avatar
If re-jetting makes the mix more rich, why not just turn out the mix knob?
Thanks,
Shandley.
