turn signals wont blink. - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 11 (permalink) Old 12-04-2010, 03:00 PM Thread Starter
Cool turn signals wont blink.
When i put new turn signals on my 2000 shadow 750 ace I was able to get them to work. About a week ago i left the lights on and killed the battery. So i bump started the bike and went for a long ride. Needless to say the battery is good and the bike runs great. I really do use my signals. I use hand signals most of the time. A week pasted and I finally noticed that my turn signals turn on and work but dont blink. When i want to turn right the right side comes on but no blink. I used to hear a clinking noise down by the turn signal relay. (the little black rectangle box inside the headlight.) Now nothing. I looked at the bulbs and the fues, they seem good. any help would be appicated.
shadow jones is offline
post #2 of 11 (permalink) Old 12-04-2010, 03:03 PM
still_bluenoser's Avatar
So they blinked when you replaced the signals? Are your new signals LED?
1983 vt500c
1979 cbx
still_bluenoser is offline
post #3 of 11 (permalink) Old 12-04-2010, 04:40 PM
sasquach's Avatar
Send a message via MSN to sasquach
Did you check the flasher ?
sasquach is offline
post #4 of 11 (permalink) Old 12-04-2010, 04:52 PM
Turn signals
The little black box that is clicking is the turn signal relay and it's probably toast. Take it to a auto parts store and match it up. Go to Honda and it will cost a lot more.
jpr1968 is offline
post #5 of 11 (permalink) Old 12-04-2010, 04:52 PM Thread Starter
when i put the new turn signals on they all worked. The flasher. is that the black box that clicks when the signals are turned on. I did un plug it and none of the signals worked. I pluged it back in and they worked. they just dont blink.
post #6 of 11 (permalink) Old 12-04-2010, 04:54 PM Thread Starter
I thought it might be the turn signal relay. i will replace that first. thanks. Do you think by me bump starting it that it could have blown the relay.
post #7 of 11 (permalink) Old 12-04-2010, 06:09 PM
No.
Southern Cruisers RC, Chapter 49 (Houston)
Buddhist Biker Dyke Electromechanial technician
PUT THIS IN YOUR TOOL BAG:--- "SELF-FUSING SILICONE TAPE" --- GOOGLE IT! I CAN'T RECOMMEND IT ENOUGH!
shadowmib is offline
post #8 of 11 (permalink) Old 12-05-2010, 11:00 AM
First check all your connections for the new signal assembly's.
What exactly changed; did you add extra bulbs in the process ??
Too little current draw and they flash too fast; too MUCH current flow and they flash too SLOW. Combined with the colder weather, it might appear that they are not flashing at all.
I suspect that a new flasher unit is in order......and if you added conventional bulbs, a "heavy duty" model might work better.
And as for the battery, without some additional tests you can't say for sure that it is not weakened and on it's way to failure. One with some age on it often fails shortly after a "key left on" episode. One thing you should do is charge it thoroughly with an external charger. Your onboard system sometimes won't do the job completely.
Having said that, I doubt that the condition of the battery has anything to do with your signal problem.
A-Rider is offline
post #9 of 11 (permalink) Old 12-05-2010, 02:05 PM Thread Starter
I got new turn signals for the back. Everything worked fine. all signals where blinking. now they are a constant light. when i put the right signal i can see a brighter light come on. it does not blink. it is just solid. that is how all four signals are now.
By the way do mortorcycle turn signals have a way of telling you the bulb is out like a car. In my truck the signals blinks faster to alert of an out bulb?
post #10 of 11 (permalink) Old 12-05-2010, 02:17 PM
Yes
jagojon3 is offline
