See if this helps Tire Dimensions Made Simple - Discount Tire
Tim 2008 Honda 750C2 sorta ![]() In 2008, 42% of fatally injured bikers were not wearing helmets; 30 states do not require helmets for all motorcyclists. So it's safer to not wear a helmet, as 58% deaths WERE wearing a helmet |
#3 (permalink) |
Depends on the bike. You should probably be ok, the thing to do is check the clearance between the fender and tire. The 110 tire is going to be about 1 cm wider, so if you only have 1 cm of clearance on either side, I'd say you might be cutting it close. Worst case though you just have to take a grinder to the fender bracket and remove a tiny bit of material.
What kind of bike is it?
I prefer dangerous freedom over peaceful slavery. ![]() ![]() Ride your own ride, don't tell me how to ride mine. |
