My shadow wont run - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-14-2011, 10:50 PM   #1 (permalink)
Default My shadow wont run
My 1985 Honda Shadow will start and idle with the choke on, but if I try to turn choke off or give it gas it dies. What is making this happen? Thanks for the help.
jdsteele3 is offline   Reply With Quote
Old 03-14-2011, 10:54 PM   #2 (permalink)
85VT1100c86's Avatar
What is the engine size?
Could be a dirty fuel filter!
My '85 Vt1100 and Tease has '09 CBF1000
85VT1100c86 is offline   Reply With Quote
Old 03-15-2011, 07:29 AM   #3 (permalink)
tubes_rock's Avatar
How long do you let it warm up before attempting to give it throttle or turn the choke off?
My Shadow is running top-notch, but you need to give it a solid minute before giving it throttle. After that, I can back the choke to 1/2 and start riding, turning the choke off completely after a few miles.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 03-15-2011, 09:36 AM   #4 (permalink)
nraluke's Avatar
Did this problem just start on a bike you have had for some time and rode?
nraluke is offline   Reply With Quote
Old 03-15-2011, 10:25 AM   #5 (permalink)
The bike is a 1985 700 VT I let the bike idle for about thirty minutes but everytime I would try to back the choke off it wouls die and same thing if I give it gas.
Old 03-15-2011, 10:54 AM   #6 (permalink)
Is your idle screw turned up enough to let it idle?
There's 3 parts to the equation of any motor running: Fuel, Air, Spark.
Main things to look at for each that are easy things to check are the following:
Fuel - fuel filter, fuel lines, be sure the petcock is turned to on, make sure it has gas in it... after these you'll start having to check carb problems like clogged jets and things of that nature. Start with the easy stuff first.
Air - check the filter, and make sure all tubing from filter into the carbs is sealed up tight.
Spark - Plugs, wires, coils
Your problem sounds like a gas problem to me from what you've mentioned.
zimdogg is offline   Reply With Quote
Old 03-15-2011, 10:57 AM   #7 (permalink)
When it idles it is idling at 1000 rpm's and i think that is low but when i turn the idle screw it dosent effect it
Old 03-15-2011, 12:02 PM   #8 (permalink)
DixieGranite's Avatar
Zimdogg has it right. Start simple and eliminate things as you go. The time spent troubleshooting will save from stabbing in the dark later.
Ride like you would with Forrest
2003 Shadow ACE 750 The Black Pearl.
Chopped exhaust
Forward Controls
Cobra sissy bar and luggage rack
T-bags roll bag
River Road tool bag
Relocated signals
Blackout work
Ride bell from George
Loose nut behind the handlebars
DixieGranite is offline   Reply With Quote
Old 03-15-2011, 12:32 PM   #9 (permalink)
+1 and...
Bingo! Might be bad gas, could be a clogged petcock, could be the carbs need cleaned, could be clogged carb jets...
K.I.S.S.
markspike is offline   Reply With Quote
Old 03-15-2011, 01:43 PM   #10 (permalink)
thanks guys
