Rotella T6 5w-40 Synthetic Oil - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-25-2011, 11:33 PM   #1 (permalink)
Default Rotella T6 5w-40 Synthetic Oil
Hi. I am new to the site. I just bought my first Honda Shadow. I have a question about the oil. The man I bought it from said he recently changed the oil using Rotella T6 5w-40 Synthetic. I looked it up and it says it's an energy saving oil. My manual says not to use energy saving. Does anyone else use this oil? Any problems? Please let me know!!!!
tsmith is offline   Reply With Quote
Old 03-25-2011, 11:56 PM   #2 (permalink)
First let me sayto the hoard.
I haven't used it, but maybe others here have. I've always used Honda's full synthetic, but I've heard you should never use energy saving oil from some and others have said they do without any problems. I feel it's best to err on the safe side and not worry, especially if your bike is still under warranty. The engine oil also lubricates the clutch and some oils can cause slippage.
Martin
Kingshead is offline   Reply With Quote
Old 03-26-2011, 12:06 AM   #3 (permalink)
Ok. If the oil causes slippage is this going to be a big deal? Basically...will it cause pricey problems or would changing the oil likely fix it?
Old 03-26-2011, 12:06 AM   #4 (permalink)
BTW, that's a very nice bike you got there!!
Old 03-26-2011, 12:08 AM   #5 (permalink)
ShadowMonster's Avatar
I believe the round label on the oil you don't want to use is "Energy Conserving"
If you look again on the Rotella site it says:
Energy saving – fuel-economy performance*
NO energy conserving label
I use it in both my bikes without issue as well as many riders here, you're good to go.
2007 Shadow Spirit C2
2007 Shadow Aero(written off July 13/11)
2005 Road Glide replaced Aero
ShadowMonster is offline   Reply With Quote
Old 03-26-2011, 12:15 AM   #6 (permalink)
Ok thats makes me feel a little better but if it happens to cause slipping will changing oil fix the problem or will it become costly?
Old 03-26-2011, 12:19 AM   #7 (permalink)
I've been using it for two years and shell rotella T dino before that and I have never had a problem and this thread will grow with confirmations of this. If you have slipping with any oil usually swapping it out for another oil will fix the situation without any repairs.
Old 03-26-2011, 12:23 AM   #8 (permalink)
Ok, great. I may change the oil just to be on the safe side. Here is the link that I was given about the oil. Take a look at it and let me know if judging by this everything looks ok. I just want a little expertise to look at it.
Old 03-26-2011, 12:27 AM   #9 (permalink)
Here's the OILOLIGY sticky link from the TECH section for some light reading, have a read
Oilology
Old 03-26-2011, 12:39 AM   #10 (permalink)
I have an '05 Aero and the manual states "Do not use oils with graphite or molybdenum additives. They may adversely affect clutch operation. Do not use API SH or higher oils displaying a circular API "energy conserving" service label on the container. They may affect lubrication and clutch performance."
If you're not having any problems, then I guess you're ok, but I would go by the book just to be sure.
-Aero-Force
aero-force is offline   Reply With Quote
