Wont start all of a sudden. Ignitor?? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-02-2011, 10:00 AM   #1 (permalink)
Default Wont start all of a sudden. Ignitor??
Ok, bike was running fine. Choke cable broke and I was starting it by pulling choke cable by hand. 1 day went to start it and it wanted to start but it just wouldnt "catch". Put new cable on when it finally came in and it still wont start. Its getting gas, you can smell it at exaust, and its getting spark but very faint. A harley tech friend of mine thinks its the ignitor because of the faint spark when we took out the spark plug and tested spark.
Any thoughts here????
zappa is offline   Reply With Quote
Old 05-02-2011, 10:06 AM   #2 (permalink)
What kind of bike is this? I'm not convinced it is not choke related?
Old 05-02-2011, 10:23 AM   #3 (permalink)
Sorry..Its a 96 Shadow 1100c.
Old 05-02-2011, 10:33 AM   #4 (permalink)
Checked all 4 plugs.. You have 2 pulse generators, 2 coils and 2 Ignitors, 1 for each cylinder. Also what is condition of the battery, NOT voltage unless it is less than 12 or more than 13.5...
I still believe it is getting Floaded. Floats getting stuck is very common and chokes also get stuck.
Old 05-02-2011, 10:44 AM   #5 (permalink)
Hmm...Flooded. Sounds logical. Maybe when I was pulling choke cable by hand the last time I may have pulled to hard and did something???
Old 05-02-2011, 10:55 AM   #6 (permalink)
That is exactly my first impression. I have a rule, If something is bad or in need of adjustment. And I have a problem pop up. DO NOT look for a new cause to the issue, until the first issue is FULLY resolved.
In the case of a broke choke cable, that I have been operating by hand. Fixing the cable may not fix the issue, because the hand actation may have cause issues, inside the carburetor, ENRICHER valve could just need adjusting
Old 05-02-2011, 05:29 PM   #7 (permalink)
Update.. took carb boots off,sprayed carb and choke cleaner in them, and then sprayed starting fluid in while cranking it over. It started right up and ran until fluid was gone. Put fresh gas in the tank, and new plugs and same thing. Only starts if I spray starting fluid into air filter.WTF !!
Old 05-03-2011, 08:27 PM   #8 (permalink)
jets are clogged.
gramez is offline   Reply With Quote
Old 05-04-2011, 06:50 AM   #9 (permalink)
jets are clogged.
+1, or pump is bad, float stuck, etc. Fuel not getting to/through carbs.....find out why and your set.
95 VT1100C
Stock Air box (UNI-Filter), HK's, River Road XL Slant Braided saddlebags, 6 degree Timing Advance, Mustang Wide Touring w/ Driver Backrest, PF3 Windshield, Chrome Engine Side covers, Lower forks, Final drive, Driveshaft, Swingarm, Master Cylinders, Brake caliper
1983 VT750C
1983 VF1100C Magna
95shadow1099 is offline   Reply With Quote
Old 05-04-2011, 07:13 AM   #10 (permalink)
Fuel pump relay or fuel pump itself maybe. Just guessing.
