Help removing left side crankcase cover 83 750 - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-04-2011, 08:12 PM   #11 (permalink)
stlouisaaron's Avatar
Default finally
after 3 days, pbblaster and a hammer drill - i won! The nuts are off and so is my crankcase cover - and my starter! I feel like dancing! One last question though - what is a good gasket sealant to use on this when I get my new gasket?
Justice. Mercy.
stlouisaaron is offline   Reply With Quote
Old 11-15-2012, 09:47 PM   #12 (permalink)
Default am i missing something
I am pulling on the left crankcase cover and it seems to want to spring back as soon as I get it close to being off the shifter...my clymers shows the plate coming off to reveal a bolt but mine is solid underneath. Do I need to remove anything on the other side?
chines is offline   Reply With Quote
Old 11-15-2012, 10:35 PM   #13 (permalink)
mattyo's Avatar
I didn't use anything except the actual gasket to seal the left crankcase and it's still holding up just fine. The left crankcover gasket is like $8. That's all I suggest. But make sure you clean off the old gasket parts first and have a good/clean metal surface for the new gasket to seat on. You'll be fine with that.
There is a pretty strong magnetic force between the stator (attached to the left crankcover) and the magnets (attached to the crank-shaft). You may need to just pull on the left crankcover harder. If all the appropriate bolts are removed, that's all you need to do.
mattyo is offline   Reply With Quote
Old 11-16-2012, 05:18 AM   #14 (permalink)
luisr320's Avatar
And be carefull with the gear that connects to the starter. It may fall off since it is not secured with anything.
That magnetic pull is quite a surprise. As Matt says, just pull hard.
Old 11-16-2012, 11:19 AM   #15 (permalink)
Default Thanks
That is awesome!!! Thanks!!! I was very hesitant to pull any harder in fear of breaking something
Old 11-18-2012, 07:53 PM   #16 (permalink)
Well you figured it out, BUT: Use a rubber mallet, not a hammer. I used a mallet and only a mallet to remove my cover. I would be worried about using a chisel on a gasket surface...
keb709 is offline   Reply With Quote
