Help - Where to buy crab parts - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-03-2011, 10:29 AM   #1 (permalink)
mooney1el's Avatar
Default Help - Where to buy crab parts
I need to buy a new float valve (some folks call them needle/seat) and a petcock for a '99 VT1100CA. None of the online sources that I find carry anything except the outrageously expensive OEM parts. Does anybody know of an aftermarket source?
Thanks,
Richard Gray
mooney1el is offline   Reply With Quote
Old 05-03-2011, 10:43 AM   #2 (permalink)
Where are you looking? How much $ are the wanting.
Get used to bike parts being expensive. There are no really cheap parts for bikes, just less expensive. You might to look for some kind of Carburetor supply house, instead of motorcycle parts houses.
93gc40 is online now   Reply With Quote
Old 05-03-2011, 10:58 AM   #3 (permalink)
Chopped 02 Shadow's Avatar
Send a message via Yahoo to Chopped 02 Shadow
I would try to find your crab parts at the local super market... but if you are looking for carb parts... try servicehonda.com.. better prices than local shops (usually)... and decent shipping.
- Pete
This is how to add a picture to your signature.
2002 Shadow Spirit 750DC Owners Manual
Mine ~> 2002 Honda Shadow Spirit 750 Bobber
Hers ~> 2008 Honda Shadow Spirit 750
Chopped 02 Shadow is offline   Reply With Quote
Old 05-03-2011, 11:39 AM   #4 (permalink)
mooney1el's Avatar
Oops can't edit title either
Thanks for the suggestion for carb parts too.
Old 05-03-2011, 11:42 AM   #5 (permalink)
Happens to everyone at least once.. good luck with your search.
- Pete
Old 05-03-2011, 12:21 PM   #6 (permalink)
mooney1el's Avatar
The OEM's are $73 for the petcock, $50 for the float valve and $27 for the gaskets. I have found aftermarket float valves with bowl gasket for earlier VT1100's for $20-30 marketed by K&L (I think that's right) but don't know if they would fit the '99 Aero.
Old 05-03-2011, 12:52 PM   #7 (permalink)
IDK if they cross either but it is easy to check. Go to any OEM site and look-up the part# for both Bikes, see if they match. That ServiceHonda site look pretty reasonable. Gaskets and orings should be easier to get although still not cheap. The other parts are going to be mostly OEM.
Old 05-03-2011, 05:09 PM   #8 (permalink)
This is one of the best places I've found to buy them.
Martin
Kingshead is offline   Reply With Quote
Old 05-04-2011, 01:14 AM   #9 (permalink)
You could check out ronayers.com, they are slow shipping, but prices seem to be cheaper than most. I bought a brand new carb for my bike and it was the cheapest I could find anywhere for an OEM brand new carb. It looks like the petcock from them is $56.10, $26.83 for the float set.
rockyroad217 is offline   Reply With Quote
Old 05-04-2011, 10:16 AM   #10 (permalink)
mooney1el's Avatar
Ordered the parts from ServiceHonda, Petcock list $73+/cost $55.69, float valve list $50+/cost $37.70 and gaskets list $27+/cost $20.32. So, y'all saved me $37+ dollars and for that I say a great "Thank You!"
