Any problems with Rotella T6? Mixed Reviews out there? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-11-2011, 11:56 AM   #1 (permalink)
Default Any problems with Rotella T6? Mixed Reviews out there?
Well after my first oil change I got ripped of at $15 a quart for honda synthetic oil so 3 quarts that means $45 alone! Seems reading oilogy thread and many others people are liking this oil alot but there are also a bit of unhappy riders out there noticing a metal to metal crunch feel, and various other problems after the change. So my question is has anyone notice even the littlest or any negatives when they made the switch? Also which filters do you buy at walmart, a car filter for a honda?
usmarinedelta is offline   Reply With Quote
Old 05-11-2011, 12:33 PM   #2 (permalink)
byggd's Avatar
$15 a quart? For that kind of danaro go with Amsoil MC oil!
88 Honda VT1100C
02 Yamaha WR426
71 Honda CB175
byggd is offline   Reply With Quote
Old 05-11-2011, 07:06 PM   #3 (permalink)
Purdue87's Avatar
I have used Rotella T for the past 2 oil changes along with the wally world oil filter and have not had any problems.
Shiny side up.....
Purdue87 is offline   Reply With Quote
Old 05-11-2011, 08:33 PM   #4 (permalink)
maurice1's Avatar
After less than 1k miles, made my gear changing sound LOUD, metal to metal. Made me nervous so I switched.
maurice
2003 vtx 1800c
maurice1 is offline   Reply With Quote
Old 05-11-2011, 09:25 PM   #5 (permalink)
ShadowMonster's Avatar
I use it on both bike with a car filter, never had a problem with rotella or rotella T6 syn .... there are probably hundreds here that use with without issue other then a few like Maurice1 that didn't care for a noise or feel, but they are far and few between.
2007 Shadow Spirit C2
2007 Shadow Aero(written off July 13/11)
2005 Road Glide replaced Aero
ShadowMonster is offline   Reply With Quote
Old 05-11-2011, 10:51 PM   #6 (permalink)
Last oil change I used Rotella T6. It's 5w40. Had some concerns as Honda calls fro 10w40. But all seems to be well. And the oil apparently holds up very well.
2006 Honda Sabre
Old 05-11-2011, 11:26 PM   #7 (permalink)
tazman9's Avatar
I have never used Rotella, & have nothing against it. However oil that is produced to protect a diesel engine that does not use a oil bath clutch like your shadow is something to think about. Diesel engines also typically run at slower engine speeds than a motorcycle, although not to many V twins run at very high RPM's either, but generally higher than most diesels. It past years I always ran auto racing oil in my bikes. Today most auto oils have additives to help reduce friction (bad for wet clutches), so I have been running MC oil. That said lots of people like Rotella, but I usually change the oil in my bike only 1 or 2 times a year. So the difference in $ is not that great.
tazman9 is offline   Reply With Quote
Old 05-11-2011, 11:28 PM   #8 (permalink)
ShadowBmtTx's Avatar
I went through 3 oil changes trying to get rid out the dreaded tick. Tried Rotella T-6, and a Wally World oil filter at about 4,200 miles after doing some research. Tick gone after a couple hundred miles. Now at 7,000 miles, and I haven't noticed any problems, or metal to metal sound. Hope this helps you. http://motorcycleinfo.calsci.com/Oils1.html Try this site for info.
2007 Spirit 1100 / Man Is Like A Tea Bag, He Only Knows His True Strength When He's In Hot Water
ShadowBmtTx is offline   Reply With Quote
Old 05-12-2011, 01:13 AM   #9 (permalink)
I just put Rotella T6 in my bike last week, it shifts smoother but now I have a ticking in the front head, going to give it another week and see.
83 VT 750 C Shadow
orlenz is offline   Reply With Quote
Old 05-12-2011, 01:36 AM   #10 (permalink)
h13man's Avatar
I changed to 5w40 Rotella almost 15,000 mi. ago. The shift from 1-2 sounds the same, (noisly)motor runs pretty quiet, and I'm presently running it at 5000 mi. per change. I'm thinking of using another brand just to see if there could be a difference. I ran it in my ZR7 and geatly improved it's gearbox compared to dino oil.
06' 1100 Spirit
71' CL 100
99' Valkyrie
Ride Bell by "Yoman"
h13man is offline   Reply With Quote
