#3 (permalink) |
I have had no problems at those speeds.
An extra gear would be nice, but not necessary. PS: I'm not sure what you mean by extended. My commute is mostly highway, and like I said...no problems. I had a concern when I first bought my VLX about the highway speeds, but other than the oft-mentioned "buzz", there were no bad reports. Incidentally, I don't get any buzz...although I find it rides smoother after I hit 65mph. Last edited by Menhir; 05-11-2011 at 11:10 PM. |
#4 (permalink) |
Because it's a cruiser.. They only had to add gears in later models to satisfy former standard and rocket riders and cagers. Final gear ratio is basically the same on the newer 5 speeds. Means you don't have to shift so much. Performance wise, yes the 4 speeds could use a 5th and the 5 speeds need a 6th, but it's a cruiser.
#5 (permalink) |
Agreed with the others, when you compare the VLX with other bikes in its class (i.e. V Star 650, Shadow 750, Suzuki S40, Suzuki S50/C50, etc) the final gear ratio is pretty much the same. You're not missing much, except extra shifting.
VLX's are fine on the freeway for extended amounts of time. It's just getting over the buzzy feeling (at 70mph, they are only just over half way to redline from what I understand). I've done 70-75mph (about 112-120kph) on the freeway several times, traveling to my sister's house. Three hours of high speed riding in a day each time I go, and I've never seen any ill effects from it except increased fuel consumption. Keep an eye on your oil as well.
You're right. I could die riding my bike. I could also die while driving my cage. I could die while crossing the street. I could die from cancer. I don't live life worrying about what might kill me. I just enjoy life as I see fit. Angela ![]() ![]() "The Flying Purple People Eater" 2001 Honda Magna 750: ride bell from I-AM-TIM and Daunte's grip ends |
#6 (permalink) |
I've done extended riding on the 5+overdrive vt500 and the 4 speed VLX and have to say that the VT500 is by far more enjoyable in most riding situations.
Also, just because you have more gears doesn't mean you have to shift more on hills etc. The VT500 will ride all day on the highway in overdrive. No need to downshift at all unless maybe passing. Just have to rock your toe a couple more times when stopping and starting.
![]() 1981 cb750c with 900f forks, cams, oil cooler. 1983 vt500c 1979 cbx |
#8 (permalink) | |
Please explain this?
#10 (permalink) | |
