Pilot Screw - Quick Question - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 27 (permalink) Old 06-20-2011, 06:55 PM Thread Starter
Endy's Avatar
I plan on adjusting the pilot screws and I had read somewhere about drilling a hole in the plugs just big enough for a small screwdriver to fit.
I was just wondering what size drillbit to use for this?
2005 Honda VTX 1300R
Endy is offline
post #2 of 27 (permalink) Old 06-20-2011, 07:03 PM
I do not remember what size it was I had one of the old timer small pocket screwdrivers that has the pocket clip on it and just found a bit that was the same size as it was.
1996 Shadow Ace 1100
Mac Fat Stakkers
National Cycle Dakota Shield
Jardine Forward controls
Tourmaster Saddlebags
hangman44 is offline
post #3 of 27 (permalink) Old 06-20-2011, 08:36 PM Thread Starter
Endy's Avatar
Do the pilot screws take a flathead or philips screwdriver? Never messed with them before.
Endy is offline
post #4 of 27 (permalink) Old 06-20-2011, 09:04 PM
AeroCapDave's Avatar
Flathead
AeroCapDave
1999 Aero 1100
AeroCapDave is offline
post #5 of 27 (permalink) Old 06-20-2011, 09:22 PM
Use a 1/8" drill bit...be careful not to drill too deep into the cap. You'll need a small flat head screw driver to adjust it.
Nine29 is offline
post #6 of 27 (permalink) Old 06-21-2011, 08:31 AM
tubes_rock's Avatar
Wrap a few turns of masking tape 1/8" from the point of your drill bit. That will keep you from drilling too deep.
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #7 of 27 (permalink) Old 06-21-2011, 10:34 AM
The Factory manuals say a 5/32 bit.
93gc40 is offline
post #8 of 27 (permalink) Old 06-21-2011, 10:35 AM
oconeedan's Avatar
Why don't you just remove the plugs? As far as I know, they are only a factory "seal" to keep people from adjusting the screws.
Drill hole slightly smaller than a self tapping screw. Screw self tapping screw into hole, then pull out the plug by grabbing screw head with pliers. Then you have easy access to the screw and can use a regular screw driver.
Dan
2000 Shadow 1100 ACE Tourer
2007 Royal Star Tour Deluxe
oconeedan is offline
post #9 of 27 (permalink) Old 06-21-2011, 10:51 AM
Dan
You can remove the plugs completely ,but then you should put some silicone into the hole to keep the screws from falling out. They will back out over-time from vibrations. If you drill the plugs and leave them in place, they can't back out, and you have access whenever you want. You also don't have to deal with the silicone.
93gc40 is offline
post #10 of 27 (permalink) Old 06-21-2011, 10:53 AM
Aced It's Avatar
Dan
Ditto this.
Aced It is offline
