I am thinking should I run the wires to the fan switch to a toggle and wire one wire on one pole and the other to the other pole or should I just wire it to the headlight si its on when the key is on. Let me know what you think. I am thinking of the toggle way but im not sure. have any of you had to do this? I do not want to cut out the auto switch completely but i cannot afford the $75 for the switch right now and I am doing alot of stop and go riding latly.
![]() " I live to ride and ride to live" |
I had to do this for a little while last summer and I would recommend the toggle switch. When I ran mine with the fan on all the time, the battery ran down. Apparently, the fan draws enough current to overdraw the charging system, or at least mine does.
#4 (permalink) |
I found one at autozone 2 pole its got a M16x 1.5 thread and fits a 85 honda civic so I assume they used this alot in 85. anyone ever use this one or know if it will fit.
#5 (permalink) |
Ok so I talked to the people that i got my replacement fan switch from on ebay. it was the wrong one so im going to return it and they are going to send me the right one. it is suppose to turn your fan on 20 degreesae sooner to keep the bike cooler. So it will be sent off tomarrow. I will not be hacking into my wiring harness afterall.
#7 (permalink) |
Get the right switch, don't hack! Good idea!
Also, don't do ANYTHING that causes extra power to go through the headlight circuit! That includes extra lights, fans, etc. The circuit is run through the starter button on the handlebars so that the headlight turns off when the engine is cranking. (So that you have more battery power for the starter.) That switch is rated for exactly the amount of power that the headlight draws and if you exceed that, the button will melt leaving you stranded at the next place you shut the engine off. No, I'm not kidding or exaggerating! --Justin
2010 Honda NT700V 1986 Shadow 700 1986 Honda Trail 110 (Postie Bike) |
#8 (permalink) |
Tubes is absolutely correct! You WILL fry your starter switch!
O'Larry Ride Bell by Kara-MIA BELL by Bear '04' Black Flame Sabre
