crack in coolant resivoir tank - Honda Shadow Forums : Shadow Motorcycle Forum
Old 07-01-2011, 07:45 PM   #1 (permalink)
Default crack in coolant resivoir tank
Was cleaning the bike this afternoon getting ready for a long weekend. and I noticed a long crack in the side corner of the overflow tank. It goes from the top corner straight down to the bottom corner.
Called the dealer and of course none in stock and the earliest I can get one is next friday....
ANy recomended temporary repairs so I dont lose a whole 4 day weekend of riding? and what would cause this to crack?
Thought about using JB weld on the crack as a temporary repair...
01 Shadow Spirit Vt1100c
JonHolder is offline   Reply With Quote
Old 07-01-2011, 08:17 PM   #2 (permalink)
Nehalem Dave's Avatar
eBay | Electronics, Cars, Clothing, Collectibles and More Online Shopping
Nehalem Dave is offline   Reply With Quote
Old 07-01-2011, 08:39 PM   #3 (permalink)
JB weld should work fine just make sure it is clean and rough it up a little I patched a big crack in the actual tank of my radiator on my pick up truck and it held for 2 years.
1996 Shadow Ace 1100
Mac Fat Stakkers
National Cycle Dakota Shield
Jardine Forward controls
Tourmaster Saddlebags
hangman44 is offline   Reply With Quote
Old 07-02-2011, 12:27 AM   #4 (permalink)
Eldorado's Avatar
Is the coolant leaking out??? If not at this time you could probably even use good ole Duck Tape as a temporary fix............
"John" 2002 Sabre
Patriot Guard Rider
Eldorado is offline   Reply With Quote
Old 07-02-2011, 01:26 AM   #5 (permalink)
tazman9's Avatar
As mentioned, JB & duck tape may work. There are also plastic welding tools, Harbor Freight sells one. I have never tried one, but it may also do the job if the other 2 don't work.
tazman9 is offline   Reply With Quote
Old 07-02-2011, 06:33 AM   #6 (permalink)
JB Weld will probably crack or break over time as it sets up brittle on plastic and doesn't expand and contract as the same rate as the plastic (had experience with this application) so it's not going to last.
A better choice is automotive GOOP or plumbers Goop, which sets up like real hard rubber and can makes a better patch. It will flex with the plastic and keep it sealed for many years. Try it, you'll find alot of other uses for it too.
