which jet kit - Honda Shadow Forums : Shadow Motorcycle Forum
Old 07-12-2011, 03:55 PM   #1 (permalink)
Default which jet kit
I have a 1998 ace 750c what would be a good starting point for re jetting if I did the bean box mod with a stock air filter and modifide stock exhaust? would a stage one kit be good for that combo? thanks
williamt is offline   Reply With Quote
Old 07-13-2011, 12:00 AM   #2 (permalink)
Normspeed's Avatar
You might give Dyno Jet, the folks who make Cobra Jet Kits a call or an email. They may have some ideas for a good starting point. They were real helpful with me when I had problems with an odd combo of Cobra exhaust, DJ Stage 1 jet kit and K&N filters. In the end the best we could do was get rid of the separate K&Ns and return to stock airbox. The VLX just would not run well across the entire throttle range without the stock airbox. I sure got good at R&Ring the carbs though.
2009 Spirit 750
Normspeed is offline   Reply With Quote
Old 07-13-2011, 12:46 AM   #3 (permalink)
You might not NEED to rejet with thos mods, only. A Dynojet Stage1 would do good for almost any bike stock to Full exhaust and airfilter mods. You are somewhere between that, but closer to stock.
Old 07-13-2011, 07:08 AM   #4 (permalink)
Ok thanks for the replies I just wanted to have the kit ready to go when I tried moding the air box just incase. I ride to work every day and did not want any down time if I can avoid it.
