VT1100--Adjusting Clutch Lever - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 11 (permalink) Old 08-27-2011, 09:33 PM Thread Starter
It's a 92 VT1100 hydraulic---Brake lever is 3 1/2" at furthest point---The clutch is a full 4"---I find myself having to let the last of it out with my longest middle finger---Would rather have it closer to the bar so I could release with the whole hand, (several times my finger slips off)---Any suggestions---Thanks
Kenny
92 Shadow VT-1100 With Samson Pipes
[/B][/FONT][/SIZE][/COLOR]
kenny4 is offline
post #2 of 11 (permalink) Old 08-27-2011, 11:57 PM
Keep dreaming. Adjustable levers are available for sportsbikes and some cruisers but I doubt for a Shadow 750 [edit] VT1100 . The pic below is the only solution I know of. The problem is you have to make absolutely certain that the modified lever contacts the clutch switch to avoid disabling the bike's safety interlock system.
2007 Honda Shadow 600
RONW is offline
post #3 of 11 (permalink) Old 08-28-2011, 03:13 AM Thread Starter
My clutch lever is built into the clutch reservoir so that wouldn't work.
Kenny
kenny4 is offline
post #4 of 11 (permalink) Old 08-28-2011, 05:13 PM
RichardL's Avatar
The mod shown above may work if you change it around a little. The adusting screw would need to be part of the lever not the mount.
I have 2003 Kawasaki Concours that had an adjustable hydraulic clutch. the adjust ment was dome by changing the length of the push rod that pushed into the master cylinder.
I dont have drawings of your lever but you may be able to modify your push rod (may be just a small die cast bump) by drilling it out and tapping it so you can insert a adjustment screw. Take a pic or two of the lever and maybe someone can come up with a solution.
RichardL is offline
post #5 of 11 (permalink) Old 08-28-2011, 07:04 PM
Hydraulic clutch's have no adjustments at the lever. Your best bet is to find a modified lever if anyone makes them.
jpr1968 is offline
post #6 of 11 (permalink) Old 08-29-2011, 11:55 PM
RichardL's Avatar
My clutch is cabled so I can't check this out on my bike but it looks like you MIGHT be able to shorten the push rod (Item 2). Item 2 costs $16 and the Bushing item 3 costs $10 so you can always order them and try mod'ing them or at least have them on hand if shortening the push rod doesn't work out.
RichardL is offline
post #7 of 11 (permalink) Old 08-30-2011, 03:49 AM Thread Starter
Thanks for the pic---I'd probably be better off just getting another #18, (the lever) off a parting out bike---Try to heat and slow bend it.
Kenny
kenny4 is offline
post #8 of 11 (permalink) Old 08-30-2011, 04:00 AM
RichardL's Avatar
Good luck with that, cast aluminum is a bear to bend even with heat due to it's porous nature. If you do get it to bend without breaking I personaly would not trust the handle, odds are it will break off just when you need it most.
RichardL is offline
post #9 of 11 (permalink) Old 08-30-2011, 06:17 PM Thread Starter
That's a good thought Richard---After I posted it I thought about it more and as you said the heating and/or bending may compromise the strength of it and could easily break off in my hand at a very inconvenient time---Oh well, I'll just have to learn to adapt to what I have.
Kenny
kenny4 is offline
post #10 of 11 (permalink) Old 08-31-2011, 01:02 AM
ernie12b's Avatar
just a thought. is your hand at the end of the handel? have you tried moving it closer to the center? also rotating the lever on the handelbar a little may help. examine your grip and see if this may help.
1983 VT500C & 2003 Kawasaki Vulcan Drifter 800
ernie12b is offline
