Lifting the VT1100 level - Honda Shadow Forums : Shadow Motorcycle Forum
Old 08-28-2011, 03:51 PM   #1 (permalink)
RichardL's Avatar
Default Lifting the VT1100 level
I picked up a center lift a few months ago so I could work on the bikes. The lift worked great for mw wifes VLX but I hated how it lifted my VT1100C so I set out to correct that. Below are pics of what I did. Hope it helps someone else.
First I got some UHMW plastic stock. This stuff is realy tough, I then drilled and tapped it for 3/8" bolts. The white paint is to make the block easier to see.
Next I drilled mounting holes in the lift and bolted the spacer block in place.
Plenty of clearance for the oil filter.
A very stable and level lift.
RichardL is offline   Reply With Quote
Old 11-09-2012, 04:41 PM   #2 (permalink)
rockbobmel's Avatar
I just got a Crafstman jack and want to do this mod. Is the jack against the motor on the front?
Bob Melnik -- 97' VT1100C2 A.C.E.
Visit my music page:
http://mysite.verizon.net/vzepjij3/
rockbobmel is offline   Reply With Quote
Old 11-09-2012, 09:10 PM   #3 (permalink)
the crankcase hanging below the frame is the problem with lifting the shadows. There are several posts on here about making brackets for your jack so you lift on the frame.
For changing the oil, some 2x6's for the wheels and kick stand are the cheapest and probally one of the most stable.
dgraves49 is online now   Reply With Quote
Old 11-09-2012, 09:51 PM   #4 (permalink)
rockbobmel's Avatar
Been changing the oil with a 3 in pan. I'm gettin this UP this winter. Jack came with straps!! Way cool.
Old 12-01-2012, 11:14 AM   #5 (permalink)
rockbobmel's Avatar
I have the hardest time doing a search here. I get better results on google and that has links back to here. I see the OP has a mod that just shime the back portion of the frame. I thought I read somewhere that you needed to shim both front and back.
Old 12-01-2012, 12:10 PM   #6 (permalink)
adlowe's Avatar
You can "instruct" Google to look here by appending " site:hondashadow.net" to the end of your search.
Art's 1999 Shadow 1100 ACE
adlowe is offline   Reply With Quote
Old 12-01-2012, 04:49 PM   #7 (permalink)
You need to shim up the front not the back. You can do both if you want to get the bike level on the lift but the front has to be shimmed so that the engine is not resting on the lift.
jpr1968 is offline   Reply With Quote
Old 02-08-2013, 06:32 PM   #8 (permalink)
Supernintendo's Avatar
RichardL: thanks for DIY pics. Your lift does indeed look nice and level. But is the engine resting directly on the left? It appears so.
jpr1968: sounds like you're not onboard with jacking up the engine directly. Is this bad for the bike?
Thanks guys
Alan
'01 VT1100C Shadow Spirit
Supernintendo is offline   Reply With Quote
Old 02-08-2013, 06:51 PM   #9 (permalink)
rockbobmel's Avatar
It does not show details but I had to custom carve the side 2x4s to clear the bolts/heat guard and kick stand spring. I finally got it screwed and glued then bolted to the jack. What a PITA, but it's DONE!!
Old 02-08-2013, 06:56 PM   #10 (permalink)
gat803's Avatar
Do you really want to take a chance on breaking a very expensive and difficult to change out, aluminum engine case.
Never lift a bike by the engine.
Hey look, a covered bridge...
gat803 is online now   Reply With Quote
