03 shadow ace vt 750 cd. Bike has sat for several months now and now does not want to start and run. The plugs have plenty of spark. I took the air filter off and sprayed some starter fluid in and the bike fired up and ran for a few seconds, so it looks like I have a fuel problem. How hard is it to get to the carb. Also does this bike have a fuel pump. I took the filter off, below the tank and it is clear.
I am not much of a mechanic so any help will great. |
download and follow the procdure in the manual, thats me less than 10min to pull them, fisrt time will take a bit longer, make sure you take that right rear cover off like it says, and the coil. its easiest. take note of the choke cable routing and dont damage the subfilter housing, if you have a problem on assem shoot me a line.
http://www.hondashadow.net/forum/53-...ace-750-a.html
