I am in the process of changing my chain on my 96 Shadow VLX with 20K miles on it.
I ordered a new O ring chain 525/120 as per OEM spec. I opened the pkg and noticed the new chain is wider then the chain currently on the bike. I also noticed it is just a standard roller chain that is currently on the bike. Is it possible to use a smaller chain like a 520 on a stock set up without any modifications? seems like the Previous owner changed it at one time and decided to use the cheapest chain. |
You should eyeball the sprockets to ensure that smaller chain did not round the edges. Departing from spec is iffy - sometimes it doesn't matter, sometimes it does. Excess chain and sprocket wear isn't the end of the world but might force replacing parts sooner than is the norm.
I view chains as equally important as my tires - only the best will do. The further and faster you go the more you flirt with trouble by using the iffy stuff. |
#3 (permalink) |
Usually an o ring chain will look wider than non o ring even the same size. got to allow room for the o rings. usually on the side plates will tell the size. Chain will last longest when changed as a system, that is both sprockets. But if the sprockets show very little wear than it won't be a big difference.
