04' VLX VT600CD Engine shutdown while riding - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-11-2011, 04:12 PM   #1 (permalink)
Default 04' VLX VT600CD Engine shutdown while riding
2004 VLX VT600CD, 14040 miles.
This morning I was heading to work.
I merged on the highway and was traveling at 70-75mph and engine shut-off, no stumble no jerk movement just shut down.
As I slowed down to about 45 mph I hit the start switch and the bike turned on again and decided to head back home (my ride to work is 40miles).
As I started to head home doing about 50 mph the bike shutdown again. I pulled to the side of the rode and started again and continue to ride back home.
This is the second time this happened to me.
The first time I was riding and when I got 50 miles and the engine cut out the same way doing about 55 mph, but it would not start up at all.
Things that I have done so far.
-When I got the bike the owner was running 91 octane and I switched to 87 octane and a oil change.
The first time after the engine shutoff. I got it home on a uhaul and changed out the battery and sparkplugs and did another oil change.
Trying to figure out where to start to check for the problem.
Any ideas would be appreciated.
Thanks
Al
2004 Shadow VT600CD
2005 VTX 1300C
Coolal is offline   Reply With Quote
Old 10-11-2011, 05:39 PM   #2 (permalink)
Scrapdog2grand's Avatar
Just the engine shut down? how about lights and indicators? oil light come on, turn signals still work?
I wouldnt be looking for a fuel problem
1999 VLX
1998 SA750
2003 SA750
Old 10-11-2011, 06:11 PM   #3 (permalink)
Super Moderator
old dad's Avatar
check both battery posts connections
2006 vlx
Old 10-11-2011, 06:19 PM   #4 (permalink)
craig s.'s Avatar
sounds like somethings possibly shortin out somewhere..maybe kill switch..idk..im not a mechanic or anything,but ive had other things do this and it was electrical in nature.
2003 vlx 600
Freedom to ride is brought to us by the men and women who gave their lives serving our country and those who continue to serve.THANK YOU!
http://www.youtube.com/watch?v=QPHJFEcrHQ4
http://www.youtube.com/watch?v=B4h7AQArOCU
craig s. is offline   Reply With Quote
Old 10-11-2011, 06:24 PM   #5 (permalink)
use lock Tight on your battery
Tom Szymborski Sr. is offline   Reply With Quote
Old 10-11-2011, 07:01 PM   #6 (permalink)
Only the engine shutoff.
Lights and indicators worked. Oil light came on and used turn signal to move over to the side of the rode.
2004 Shadow VT600CD
2005 VTX 1300C
Old 10-11-2011, 07:42 PM   #7 (permalink)
If I were putting money on it , I go with the Ignition pulse generator, IF you have the 2 wire style.
I have to diff wiring diagrams for the same year VLX, one shows 2 wire, one shows a 4 wire. they get hot and stop working.
I'd do some more research and see if you can find out if this is has been the case with simalar complaints and symptoms.
It could be the stop run switch, but I doubt its a problem b4 the switch, as the black and white wire that feeds power to the stop run switch, also feeds power to the starter switch. I dont think your problem is here, but could be. I hear its a common problem.
wouldnt hurt to take it apart and clean it properly, if you have the tools and are capable.
It could also be a wire shorting to ground, chaffed and rubbed through.
Anyody have some info on the IPG, 2 wire or 4 wire?
How about failure rate, common enough?
1999 VLX
1998 SA750
2003 SA750
Old 10-12-2011, 05:16 AM   #8 (permalink)
gmck's Avatar
my vlx has a fuel pump, that could be the issue too, not sure if later ones still used the pump or gravity.
gmck is online now   Reply With Quote
Old 10-12-2011, 05:59 AM   #9 (permalink)
John Hopkins's Avatar
No way of telling you what is wrong with your bike..these intermittant faults are always the hardest to find..put the bike on the centre stand and start the engine, then with the bike ticking over move the sidestand to see if the bike cuts out..if you only have to move it a small amount it could be dropping or bouncing because of vibration, touch the connectors to the earth or frame points to see if any are loose enough to stop the engine, look at exposed connectors first, the weather may have damaged them..then look at things that have been worked on recently to make sure nothing is shorting out, then loose fuses. try to keep the bike ticking over while you do all this. pull firmly at the wires you check, sometimes the outer sheath remains undamaged while the inner wires fray, they remain in contact held in place by the sheath until they vibrate apart.
Take your time and do it right, it's worth it.
John.
Old 10-12-2011, 08:19 AM   #10 (permalink)
LIMagna's Avatar
The 04 should be gravity fed. However, if there's an issue with the tank vent (cap), that could cause a problem such as this. Also, the vacuum petcock would be something to look at too. You would need to determine whether fuel starvation is the cause of the problem or if it's electrical. From the description, it doesn't sound like starvation since it would probably stumble a bit before dieing.
- Charlie
96 VF750C Magna - Pearl Shining Yellow
V&H Pipes - Factory Pro Jet Kit
Race Tech Cartridge Emulators & Springs
Progressive 440 Shocks
07 VT600CD Shadow VLX - Candy Dark Red
DynoJet Jet Kit
V&H Cruzers
LIMagna is offline   Reply With Quote
