VT1100 project - Page 5 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-15-2012, 03:58 PM   #41 (permalink)
kenny83's Avatar
I think it will be just fine, a tig welder would be better though
kenny83 is offline   Reply With Quote
Old 11-18-2012, 07:01 PM   #42 (permalink)
Doorman's Avatar
Back on the tank today then....
First, stretching it..
Took out the skeleton and base plate, and welded up the inside. Then got a flappy wheel on the grinder and started cleaning up the welds
It's a tad wavy, but, the main **** on the entire thing is that when blending in the welds, I took a bit of steel too thin revealing a couple of small holes. I figured I'd build up the hole with weld, tried, and blew straight through
Oh, and I welded in the 'U' shaped piece at the front I'd mentioned on a previous post.
So the plan is to cut out a section and stick in another piece. Hopefully I haven't created any other majorly thin parts.
After all this is done, got the plate that goes over the diamond shaped spine to get in sorted, so it's shaping some side pieces for the bottom of the tank to it.
Pressure test and away we go. I can help some of the wavy business with filler, but, if I'm putting the spine over the outside, fingers crossed it'll 'appear' OK. It doesn't have to be absolutely perfect to be honest - end of the day it's made by someone that's clueless so we have to be realistic! LOL
Doorman
Live life in the Shadows and live the dream!
Doorman is offline   Reply With Quote
Old 11-18-2012, 07:08 PM   #43 (permalink)
04LowShadow's Avatar
Oops!!!
04 Aero 750
Cobra HP Pro Exhaust,Wrapped
De-snorkeled,K&N AF, Dyno Jet JK
Blue Collar Bobbers 31" Drag bars and Risers, Avon Grips,Baron Tach
Goodrich Braided SS/Black Teflon front brake line, EBC HH Front brakes/EBC Rear shoes
ScootMods 4" Control Extensions
ScootWorks Front/Rear 1.5 Lowering Kit
Shaved Stock Seat (Self made)
Flush Mount Tag (Self made)
04LowShadow is offline   Reply With Quote
Old 11-19-2012, 04:14 PM   #44 (permalink)
its so biiiiiiig. i guess paint will make it look better
TCazes is offline   Reply With Quote
Old 11-19-2012, 07:12 PM   #45 (permalink)
Doorman's Avatar
Ironically, it's not actually that much bigger than the stock tank width wise, the stretched part does make it look considerably longer than it is, but, some of that will be cut into and shaped as the front of the seat pan. In context with the rest of the body work, it should even out
Doorman
Old 11-20-2012, 12:34 AM   #46 (permalink)
davelisowski's Avatar
do you want to come work for me?
Live to ride another day!
davelisowski is offline   Reply With Quote
Old 11-20-2012, 05:50 AM   #47 (permalink)
Doorman's Avatar
If you want to pay for the flights LOL
Doorman
Old 12-01-2012, 12:35 AM   #48 (permalink)
zilliox's Avatar
take the stock tank and stretch it and put what ever skin you want over it. just my two cents. cheeers.
1996 ACE
zilliox is offline   Reply With Quote
Old 12-22-2012, 02:09 PM   #49 (permalink)
Buuuump
: off like a terd of hurtles :
bigooomp is offline   Reply With Quote
Old 12-22-2012, 02:37 PM   #50 (permalink)
Doorman's Avatar
Originally Posted by bigooomp View Post
Buuuump
Hey dude, I've had a bit of a delay with this thanks to ill health and making a couple of chopper pushbikes. Also, lost my job so money's been super tight too.
Will be back onto it after Xmas though
Doorman
