85 vt700 Brake specs - Honda Shadow Forums : Shadow Motorcycle Forum
Old 01-05-2012, 09:56 AM   #1 (permalink)
Default 85 vt700 Brake specs
i read inside my drum that the rear drum's max wear limit is 161 mm. anyone know what they were new? i'm having a hard time finding a used wheel that is better than the one i have now (mine is well over the 161 mm limit and the rear brake no longer engages)
danteisme is offline   Reply With Quote
Old 01-05-2012, 10:55 AM   #2 (permalink)
Custom85VT's Avatar
Don’t know if its exactly the answer you were looking for but the Honda manual list the standard measurement and the limit @ 161.
ϟ
And in those days shall men seek death, and shall not find it,
and shall desire to die, and death shall flee from them.
ϟ
Custom85VT is offline   Reply With Quote
Old 01-05-2012, 11:03 AM   #3 (permalink)
thats interesting. i just got a new to me rear wheel, i cleaned out the surface rust inside the drum and with my digital caliper i'm getting about 159.5mm. so i guess this one should work for a while then? i dont know how long it takes to wear down 1.5mm of brake drum material.
Old 01-05-2012, 11:11 AM   #4 (permalink)
Custom85VT's Avatar
It should last a lifetime unless you have sandpaper brake shoes, it is not properly adjusted or you ride with your foot on the pedal.
ϟ
ϟ
Old 01-05-2012, 11:19 AM   #5 (permalink)
i just replaced the shoes as well. the last one worked fine up until last year.
