#42 (permalink) |
Thanks xsive! 3rd time seems more like a routine, but it is still exciting!
So I finally tested out the sand blaster tonight. Being a n00b on blasting, at first I didn't realize I could control the sand flow with the valve on the blaster and had it wide open and was getting giant steams of sand. It was more of a sand fountain than sand blaster. So after becoming less n00bish I tweaked the sand flow rate until I had something that seemed reasonable. Hard to explain empirically but looked like maybe 90% air and 10% sand, at least compared to the sand fountain I had earlier. I'm still not sure how to tell when you have the "optimal" sand/air ratio but I bet it's one of those things you get a feel for after a while and probably depends on personal preference as well? But any suggestions are definitely welcome. I did a test run on the water pump head and was very pleased with the result. The compressor was able to keep up with the air flow demands except I'm skeptical on one thing. My air tank will compress up to 140psi just fine and I have the regulator at 100psi because at that setting the blasting tank reads 90psi. I assume there's a pressure drop across the air filters the same way you get a voltage drop across a resistor but a 10 psi drop just seems high to me. I do have 3 filters in line so maybe that's reasonable after all? Anyway, it still makes aluminum look nice and clean again. ![]() ![]() Yes, I know I missed a couple spots. |
#44 (permalink) | |
Also, I'm not even sure I should be blasting at 90psi. I should probably look into that. |
#45 (permalink) |
Well finally a little update. Still cleaning and blasting but I'm getting there. Had to a take a little tangent and do a more thorough job of sealing up the seams and bolt holes on the blasting cabinet because #8 silica was flooding the basement and my lungs. But these little deals worked great for the gasket surfaces and piston heads:
Pack of 5 2" Fine Grade Fiber Grinding Discs And it seems my mad blasting skills (yeah right) were good enough to avoid hitting the gasket surfaces with the blasting, at least to the naked eye. I still have to give the gasket surfaces a wet sand and polish them up. ![]() I still haven't decided if I want to just clear coat the bare aluminum (because I like the look of raw metal) or go for some metallic dark red to accent the engine. In my mind it would look awesome to flat black everything else and have the metallic red engine as the focal point. A man can dream can't he? Oh yeah, and if you live near a Harbor Freight, these come in very handy. Sometimes they say, "original coupon must be presented" but I have not had any troubles using a printed copy of them yet. http://slickdeals.net/forums/attachm...2&d=1328131775
![]() 1983 vt750 - "Fra-Hankenstein" (restoration in progress, click for the full story) Last edited by mattyo; 03-13-2012 at 01:55 AM. |
#46 (permalink) |
The clear coated bare aluminum would look great, the only other option
![]() 1981 cb750c with 900f forks, cams, oil cooler. 1983 vt500c 1979 cbx |
#47 (permalink) | |
#48 (permalink) | |
I had thought about trying to paint the bike so it looked like it was made of LEGOs (gloss black LEGOs?) but sounded like too much work. |
#49 (permalink) | |
#50 (permalink) |
Tonight I got the rear cylinder parts blasted, pulled the rings off the pistons and cleaned them up with the abrasive disks. Man this is time consuming! Still have to clean up the rocker cavities and rocket heads, pull the bearings, clean the main case and install the new bearings. I have a lot of gaskets and O-rings to buy. Oh well, I'm learning and that's what counts right? And hopefully I have a working engine after this!
