gas tank dent - Honda Shadow Forums : Shadow Motorcycle Forum
Old 02-04-2012, 04:32 AM   #1 (permalink)
Default gas tank dent
So i bought my first bike not to long ago and was so desperate to get one i didnt care much about the dent it has on the right side of the gas tank. Of course now that i have been riding it a bit its becoming more of an eye sore. it looks like they painted over it with some flat black paint that seems to be holding pretty well. I realize that the best bet would be to just get a new tank but cant really afford that right now. I was wondering if i could throw some bondo or something over it smooth it out and paint it. Any help would be greatly appriciated. Even if its just hey you idiot thats a bad idea.
some pics of the dent
Thank you
Doc V is offline   Reply With Quote
Old 02-04-2012, 06:41 AM   #2 (permalink)
That dent looks a little too deep for just bondo. You need to get as much of the dent out as possible before putting on bondo. It doesn't do well with thick coats. On top of that the dent has multiple pockets which will make removal a little harder. You may need professional help with that one.
Schattenreiter is offline   Reply With Quote
Old 02-04-2012, 07:42 AM   #3 (permalink)
yeah i was afraid of that. bars are pretty bent to. maybe 2.5 inches off. fml. oh well still rides like a champ
Old 02-04-2012, 07:52 AM   #4 (permalink)
still_bluenoser's Avatar
If your on a tight budget than you could give it a try. Fill it with fiberglass though, it doesn't shrink and crack at all when it cures in thick coats. Top coat the fiberglass with bondo, than spot putty.
Wont be a professional job by any means, but it sure will be better than what you've got.
And replace those bars
1983 vt500c
1979 cbx
still_bluenoser is offline   Reply With Quote
Old 02-04-2012, 09:58 AM   #5 (permalink)
Sounds to me like the bike may have been in a crash. You might just want to check into the bent bars a little further for your safety.
Just my 2 cents.
2006 Honda Sabre
Old 02-04-2012, 01:15 PM   #6 (permalink)
If you are patient you can get a tank off of Ebay for about the same amount of money as buying bondo, sand paper, and paint.
The Ebay tank may not be perfect either but it will look better than the one you have.
And if that's not an option then for a REALLY CHEAP but not perfect repair, get some sort of vinyl decal that would spread completely over the dent. You can have a graphic that would "hide" the fact that there's a dent. Then you could either pack some bondo in the dent or just have the vinyl decal float over the dent.
To keep the decal from sticking to the dent and then following the contour, just spread a tiny bit of oil where you don't want the decal to stick.
Hey, you wanted CHEAP, right?
Inferno is offline   Reply With Quote
Old 02-04-2012, 01:56 PM   #7 (permalink)
Do a Youtube search on "paintless tank repair". With a properly bent steal rod those dents can be massaged, out from the inside.
Old 02-04-2012, 10:05 PM   #8 (permalink)
i've have dealt with a similar situation but i ran into a lot of opposition towards using bondo on a motorcycle. do you think they can do a PDR job without a shiny surface cus after watching some videos i see that they use the reflection of a card to tell when the surface is just right. also has anybody had any luck using a hot glue and slide hammer kit or is it too think?
1988 Honda VT600c
Ps69pher is offline   Reply With Quote
Old 02-04-2012, 10:15 PM   #9 (permalink)
John Hopkins's Avatar
Ebay tank is the best option..second choice is see if a tire lever will reach the dent from the filler neck and gently try to tap the dent out by hitting the lever against the inside of the tank with a hammer, third option ride it as it is..
John.
John Hopkins is online now   Reply With Quote
Old 02-04-2012, 10:22 PM   #10 (permalink)
Lakota's Avatar
This. It's your best bet. At least try it, first.
Peace.
-john
It's not the bike; it's the rider.
'03 Honda 750 Shadow Spirit; '93 Yamaha 750 Virago; '96 Harley 1200 conversion; '84 Harley ironhead.
Ride bells by old dad
Lakota is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
