Spark Plug Condition - Honda Shadow Forums : Shadow Motorcycle Forum
Old 02-04-2012, 07:56 AM   #1 (permalink)
Default Spark Plug Condition
I just changed the spark plugs on my 1998 VT1100C with 14,000 miles on it.
No service history, so I dont know when they were changed last.
Attached is a picture of the ones I took out.
They were quite oily, and the picture was taken after I wiped them with a rag.
I noticed that whoever fitted them, didnt screw them in very tight, they were barely screwed in, the washers were were not compressed at all, so I was surprised at how loose they were.
Any opinions on the condition?
I also changed the air filter which appeared filthy, completely black.
corrcullen is offline   Reply With Quote
Old 02-04-2012, 07:58 AM   #2 (permalink)
Big B's Avatar
Those plugs look like their practically new. No wear on the electrodes at all. Hang on to them.
Bernie
08 M109R *SLAMMED*
02 Sabre, gone but not forgotten
IS IT SPRING YET?
Big B is offline   Reply With Quote
Old 02-04-2012, 08:04 AM   #3 (permalink)
ok fair enough. Notice the crack around the collar of the electrode on the first plug on left, am guessing that happened when I removed it and dropped it on the drive.
Old 02-04-2012, 08:06 AM   #4 (permalink)
1+ for Bernie. I bet the last owner replaced them shortly before selling. They look hardly used. That crack appears to be new so it probably happened because you're a clutz.
jpr1968 is online now   Reply With Quote
Old 02-04-2012, 10:25 AM   #5 (permalink)
Did you drop the 3rd from the left too? It looks like the gap is 1/2 or less than the rest of the gaps.
2007 Spirit 1100, Hard Krome pipes, K&N, DynoJet Stage 1, Saddlemen Tattoo Slants, Switchblade Windshield
Not enough miles...yet
FreakShow is offline   Reply With Quote
Old 02-04-2012, 11:29 AM   #6 (permalink)
Other than the absence of any wear, they also appear to be burning perfectly.
edit. It is not necessary to muscle a spark plug down very tight. It depends on what motor they are going into, but similiar to an oil filter, turn 'em until the washer touches the head and go another half turn or so. For plugs without the washer just a gentle pull after the shoulder hits the head. Remember, heads are aluminum and very soft. Always use anti-seize on the threads of new spark plugs.
...She said, I should go climb a tree...
gat803 is online now   Reply With Quote
Old 02-04-2012, 11:58 AM   #7 (permalink)
I read about a new tech that uses laser spark instead of spark plugs.
Those plugs look fine to me.
walker311 is offline   Reply With Quote
Old 02-04-2012, 12:36 PM   #8 (permalink)
Cleanum, Gapum and Runum. They are fine........ Relatively new or from well maintained bike. My plugs have over 15000k on them and look almost the same.
Do you know which hole each plug came from? With these 4 plug V-twins, it helps to know which plug is which, when trying to read the plugs.
Old 02-05-2012, 11:19 PM   #9 (permalink)
I don't think I would reuse plug on left with that crack in it. Did plug #3 come out with the gap that close? No need to over tighten when reinstalling, you will be sorry if you do. Anti-seize is your friend.
trabb47 is offline   Reply With Quote
Old 02-05-2012, 11:23 PM   #10 (permalink)
The rule of thumb is once you drop a spark plug you should drop it in the garbage can.
It's not worth the hassles it can cause if it's been internally damaged.
I'll add that they all appear to have been tap gapped. It's where the spark plugs started out with a much larger gap and were tapped into gap. This is a common backyard mechanic method of gapping plugs and it's HORRIBLY wrong.
You actually want the bottom electrode to be horizontal, or parallel, to the center electrode. This gives a greater area of spark jump. The way they are set they will burn out quickly and won't give a great spark.
Start with a fresh set of plugs and gap them properly.
Inferno is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
