Eliminate rubber handlebar mounting? - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 02-21-2012, 08:58 AM   #11 (permalink)
Buicknick72's Avatar
Originally Posted by oconeedan View Post
Convict, get your bike up to highway speed, take your left hand off the bar, and push slightly with your right away from you. Your bike will go left. Unless you are living in a parallel dimension. It's called counter steering.
I think there is some mix up on rights and lefts in this discussion. Push on left handle bar the bike goes left. That is counter steer, because you are turning the tire the opposite direction you want to go.
Buicknick, I hope you are happy after removing the rubber mounting. I can't imaging wanting to do that, as it sounds like a buzzing discomfort. I have never needed more control than I already have.
You Ace is similar to my Aero that I had. I didn't mind the rubber bushings on that much because it was a lazier bike. And in just daily riding I don't really notice it on the '86 either. But in harder leans and side to side flicks, especially on not so perfect pavement, the rubber isolators become very noticeable.
Motorcycles are not a form of expression, if you want to express yourself, write a poem, if you want to ride, get a motorcycle.
1986 Honda Shadow VT1100 (sold)
1957 BSA Bantam D3 Major restoration project
1981 Honda CB750F
2008 Kawasaki KLR650
2011 Triumph Sprint GT
2006 Kawasaki ZX14 (stolen)
2006 Yamaha FZ6 (sold)
1999 Honda Shadow Aero 1100 (sold)
1980 Yamaha XT500 (sold)
Buicknick72 is offline   Reply With Quote
Old 02-21-2012, 10:05 AM   #12 (permalink)
oconeedan's Avatar
My bad, yes, push in the direction you want to go, yes a mix up.
2000 Shadow 1100 ACE Tourer
You deserve a good knife!
oconeedan is offline   Reply With Quote
Old 02-21-2012, 11:35 AM   #13 (permalink)
h13man's Avatar
Hondaline Billet Handlebar Clamp - This is an option. Works good for me. There are different makers of these. The only complaint I have is the one I purchased partially blocks my "indicator lights" view.
06' 1100 Spirit
71' CL 100
99' Valkyrie
Ride Bell by "Yoman"
h13man is offline   Reply With Quote
Old 02-21-2012, 08:33 PM   #14 (permalink)
If you get movement of the bars relative to the triple clamp, I betcha the rubbers are worn or disintegrating because of age. My 25 year old VT1100 bars do not move independent of the triple clamps. If the rubber mounts are in good condition, normal riding will not have a "sloppy" feel - they are supposed to be stiff and dampen vibration, not cause "slop".
Black Beast = '71 CB750
Lazarus = '86 VT1100C rescued from a salvage yard.
GrumpyOldMan is offline   Reply With Quote
Old 02-22-2012, 08:03 AM   #15 (permalink)
I say you just scrap the handlebars altogether and get yourself some clip ons!
Damian
Image is pointless if you don't do the riding part; get out on the road and out of the bar!
Damian
'00 Sabre
damian.garcia83 is offline   Reply With Quote
Old 02-22-2012, 09:17 PM   #16 (permalink)
Send a message via AIM to slim Send a message via MSN to slim Send a message via Yahoo to slim
Buicknick72 im thinking the same way,i can sit on my 1100 spirit and push my bars forward about an inch.i got 16in apes im gone install and my concern is if i get that much play with stock bars and every thing tight then what will it be like with the apes.
slim is offline   Reply With Quote
Old 02-23-2012, 08:23 AM   #17 (permalink)
I can't push mine back and forth a full inch(I don't think it's that much, haven't actually measured it), but that all depends on the handle distance to the rubber bushing. Those apes will increase the handlebar-to-bushing length and increase any slop. Weather your bushings are worn out or it's the way the bike is from the factory, it may get real annoying with the apes. What I would do is, leaving everything hooked up to your factory bars, unclamp them and move them foward out of the way, and just clamp in the new apes. Push them front to back and decide from there whether it's too much for how you ride.
"normal riding" on mine doesn't have a sloppy feel. Going over crappy pavement (i think my suspension maybe tuned stiff also) and in hard turns or quick side to side transitions they show their slop.
1981 Honda CB750F
Old 02-23-2012, 08:27 AM   #18 (permalink)
I did find a previous thread where someone used large washers and drilled out the centers to go around the inside metal piece of the bushing and allow the risers to clamp directly to the triple clamp. That's what I'm gonna do this weekend.
1981 Honda CB750F
