Need help trouble after Seafoam 84 vt500 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 02-28-2012, 06:11 PM   #1 (permalink)
Default Need help trouble after Seafoam 84 vt500
so yesterday i put some seafoam in the gas tank ( the tank was about 1/4 full when i added it) and engine oil to try to clean up the insides, i went for a spin yesterday and no problem.
today i went to work in the morning with no problem but today afterwork was having trouble starting the bike and once it got started it would die after a few revs, in neutral or while in 1st gear.
i switched the gas switch to reserve thinking maybe i could get a lil clean gas/ no seafoam mix and it started and revd with no problem, i made it to a gas station and filled about half way with premium after about 3 blocks i switched it back to the regular gas line and made it home no problem.
i was thinking maybe there was more seafoam in the tank than gas perhaps, but i didnt even put all that much as i was trying to test it out first before dumping the whole bottle in.
any advice or tips.
Thank you
MizzenMast54 is offline   Reply With Quote
Old 02-28-2012, 06:31 PM   #2 (permalink)
tcbeard's Avatar
You should only be adding 1 oz of Seafoam per gallon of gas. The Seafoam will do it's magic over a period of time when mixed that way. If you only had a 1/4 of a tank of gas it sounds like maybe you added too much Seafoam. Fill the tank, add 3 to 4 oz's of Seafoam and give it some time and miles...
____________________________
'07 Honda VT1100 Shadow Spirit
'99 Kawasaki Concours 1000
'94 Yamaha Virago XV535
tcbeard is offline   Reply With Quote
Old 02-28-2012, 06:34 PM   #3 (permalink)
craig s.'s Avatar
was there only a 1/4 tank of gas the whole time until your trip home after work when you stopped and filled it up? im not sure,but i think you shouldve had a full tank or filled it up completely after putting the seafoam in the tank. ive never used the seafoam stuff,so im not 100% certain..but id think youd have to have a full tank in order for it to work properly and be a better ratio mix of gas/seafoam.
2003 vlx 600
Freedom to ride is brought to us by the men and women who gave their lives serving our country and those who continue to serve.THANK YOU!
http://www.youtube.com/watch?v=QPHJFEcrHQ4
http://www.youtube.com/watch?v=B4h7AQArOCU
craig s. is offline   Reply With Quote
Old 02-28-2012, 06:45 PM   #4 (permalink)
it was about 1/4 tank last nite, i added seafoam then went for a 15 min ride last nite, then my ride to work this morning and then afterwork it sputtered then i added about 1.5 gal premium gas.
thanks for the good info guys
Old 02-28-2012, 07:20 PM   #5 (permalink)
Did you put oil in the engine or are you saying you put oil in the tank? If you put oil in the gas tank that would explain the problem.
Tim "MrGrinch"
2010 Honda NT700V
1984 Honda VT500C
MrGrinch is offline   Reply With Quote
Old 02-28-2012, 07:37 PM   #6 (permalink)
still_bluenoser's Avatar
What do ya have your idle set to? And change you oil now if you added seafoam to it.
1983 vt500c
1979 cbx
still_bluenoser is offline   Reply With Quote
Old 02-28-2012, 09:05 PM   #7 (permalink)
no oil in the gas tank, that would be retarded
Old 02-28-2012, 10:28 PM   #8 (permalink)
LOL! I was just being a smart a$$, but you might be surprised at some on the things I have run across or seen people do.
Tim "MrGrinch"
2010 Honda NT700V
1984 Honda VT500C
Old 02-29-2012, 08:06 AM   #9 (permalink)
Seafoam takes time to do its magic sometimes. It can also break lose small particles of dirt that clog the small journal/ports in your carbs, so it still possible that you may need a good manual carb cleaning.
It also possible that your entire fuel system need to be cleaned. The tank, petcock, filter and carbs need to be gone thru. Seafoam can clean, but can also cause stuff to break lose and plug up filters over time.
Old 02-29-2012, 09:11 AM   #10 (permalink)
SnoGhost13's Avatar
It ran fine on reserve to the gas station... Since all you're doing by switching to reserve is using a lower opening on the petcock (same fuel as the on position) it would lead me to believe you just ran low on gas. I've never heard of using too much Seafoam to the point of having engine problems.
Sent from my Samsung Epic 4G Touch using Motorcycle.com App
Joe
08 VT750C2 Shadow Spirit
SnoGhost13 is online now   Reply With Quote
