Bike will not start when hot - Honda Shadow Forums : Shadow Motorcycle Forum
Old 02-29-2012, 02:59 PM   #1 (permalink)
Default Bike will not start when hot
Hi Everyone,
I have an 83 VT500c and here is a quick description of my problem, I'm hoping that you guys can give me some things to troubleshoot, if you need more info please let me know.
The bike will not start after it has been running for more than 5-10 minutes. I have to wait 30-40 minutes for it to cool down, then it will start. It has a new battery, I've replaced the coils will used coils that were taken off of a working bike and still have the same outcome. When I try to start it when it's hot, it tries to turn over and doesn't. I do get a few backfires if I try for to start it for too long.
Not sure if this something electrical or if it's something with the gas being too hot, I've heard of that before, not sure how to troubleshoot. Any help would be appreciated. Thanks!
83 Honda VT500
syren is offline   Reply With Quote
Old 02-29-2012, 03:16 PM   #2 (permalink)
oconeedan's Avatar
So the engine is turning over, but won't start, when it's hot?
2000 Shadow 1100 ACE Tourer
You deserve a good knife!
oconeedan is offline   Reply With Quote
Old 02-29-2012, 03:25 PM   #3 (permalink)
CBH
CBH's Avatar
The starter brushes are probably worn out.
Shadow VT700C................. Goldwing GL1500................ Savage LS650
CBH is offline   Reply With Quote
Old 02-29-2012, 03:44 PM   #4 (permalink)
oconeedan's Avatar
That was my first thought, but then he said it backfires when he tries to start it when hot. That would indicate something other than the starter.
Old 02-29-2012, 04:44 PM   #5 (permalink)
Hi guys,
The engine is turning but wont start. It doesnt alway backfire but does if i try to start it for long enough.
83 Honda VT500
Old 02-29-2012, 04:59 PM   #6 (permalink)
How about valve adjustment?
Sometimes they act like that when the valves are too tight.
callmeal is offline   Reply With Quote
Old 02-29-2012, 07:00 PM   #7 (permalink)
CBH
CBH's Avatar
Originally Posted by syren View Post
Hi Everyone,
Hi guys,
We seem to be getting two different stories here!
Old 02-29-2012, 08:49 PM   #8 (permalink)
oconeedan's Avatar
I would lean toward a carb problem.
Old 02-29-2012, 08:55 PM   #9 (permalink)
Ralph Ky's Avatar
I think i understand that it is cranking but does not start but will backfire if it is cranked for more than should start the bike.
I have an 85 vt500 that does the same thing sometimes .
It will cold start just fine with choke .runs great but if you shut it off it will start back if if you start it within a couple minutes ...
But if you let it sit for 5 - 10 minutes it will crank backfire crank backfire.....
If you let it sit for 20 to 30 minutes it will start right up and run like a top....
Shoot Low Sherriff they're Riding Shadows
Ralph Ky is offline   Reply With Quote
Old 03-01-2012, 02:19 PM   #10 (permalink)
That's a good description Ralph, I was confusing cranking and turning over.
What should I be checking next?
83 Honda VT500
