BikeMaster Turn Signals - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-01-2012, 06:05 PM   #1 (permalink)
Default BikeMaster Turn Signals
I bought new front and rear turn signals for my '83 Honda Shadow VT500C. These are the ones I bought: Honda VT500 C FT Shadow Ascot REAR turn signal lamp light left right 83-86 | eBay
Honda VT500 C FT Shadow Ascot FRONT turn signal lamp light left right 83-86 | eBay
My question is what stems do I need for the front and rear?
I've read about people having problems with the rear stems, being too long. Do I need short stems for mine? I think the long stem, with the long bolt is WAY too long for my bike. Do I need part #26-4504 my bike?
Turn Signal Stems
Also, do I need the short stems for the front as well? Same part # as I listed for the rear?
Thank you for your time!
Ethan
1983 Honda Shadow VT500C
Ethan
Ethan1 is offline   Reply With Quote
Old 03-01-2012, 07:32 PM   #2 (permalink)
Windwalker61's Avatar
My 84 VT500 has the 4503 (long) on the front and the 4505 (short) on the rear.
Sent from my Motorcycle iPhone app
If life gives you melons, you may be dyslexic.
'84 VT500C
Patriot Guard Rider
Jerry
Windwalker61 is offline   Reply With Quote
Old 03-01-2012, 07:38 PM   #3 (permalink)
Originally Posted by Windwalker61 View Post
My 84 VT500 has the 4503 (long) on the front and the 4503 (short) on the rear.
Thank you. I assume you meant the 4504 (short) for the rear?
Ethan
Old 03-01-2012, 07:41 PM   #4 (permalink)
Ethan
Old 03-01-2012, 07:51 PM   #5 (permalink)
Also, how did you wire the front turn signals? My fronts only have 2 wires, while the new ones from BikeMaster have 3 wires. One Red, one Black, and one Black with White Stripe. Thank you!
Ethan
Old 03-02-2012, 12:28 AM   #6 (permalink)
Sorry, fat fingered that one. 4505 on the rear, 4503 on the front.
'84 VT500C
Patriot Guard Rider
Jerry
Old 03-02-2012, 12:32 AM   #7 (permalink)
Fronts should be 3 wire, ground, turn, and running. Rears are 2 wire, ground and brake/stop. Mine were there, but the stems were broken. The last ones I ordered were hard plastic in the center, not rubber. You want the rubber if you can get them.
'84 VT500C
Patriot Guard Rider
Jerry
