Float setting VT 700 confused- HELP - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-18-2012, 02:57 PM   #1 (permalink)
Default Float setting VT 700 confused- HELP
I'm confused ..from the manual it says to measure carb slightly inclined and the tang just contacting valve.
Ques: should the needle valve be closed when measuring or open but just at contact between the needle valve and the Tang?
jeff57 is offline   Reply With Quote
Old 03-19-2012, 03:35 PM   #2 (permalink)
Anybody?
Old 03-20-2012, 07:14 AM   #3 (permalink)
tubes_rock's Avatar
The valve should be closed. You incline the carb just so that gravity closes the valve, but not inclined so much that the weight of the float compresses the spring in the float needle.
--Justin
2010 Honda NT700V
1986 Shadow 700
