Oil between lines on dipstick - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-19-2012, 12:34 PM   #1 (permalink)
ms21117's Avatar
Default Oil between lines on dipstick
I have a 2006 Shadow Spirit (750) ...does anyone know how much oil I need to add if the oil level is at the bottom line of the dipstick in order for the oil level to go to the top of the dipstick? I cked Oilogy but couldn't find it....Thanks!!!!
ms21117 is offline   Reply With Quote
Old 03-19-2012, 01:09 PM   #2 (permalink)
Oil is at lower line: 1/4 Quart then recheck. You don't need to go to upper line. If you are not using/losing/burning oil between changes I would only fill to between the two lines and try to hit the middle as it is very bad to overfill or underfill.
gdb069 is offline   Reply With Quote
Old 03-19-2012, 03:04 PM   #3 (permalink)
rpneal44's Avatar
Send a message via Yahoo to rpneal44
Open a bottle of oil and fill it until it says full. You can only buy oil in quart bottles any way, unless you want a jug of it.
Rusty ole bike rider dude ('84 VT-700, '00 750 ACE)
Phildo
rpneal44 is offline   Reply With Quote
Old 03-19-2012, 03:08 PM   #4 (permalink)
oblivion_twister's Avatar
yeap, add and check
oblivion_twister is offline   Reply With Quote
Old 03-19-2012, 05:11 PM   #5 (permalink)
ms21117's Avatar
Thanks GDB.. That's just what I needed...it's not burning any, but oil changes are a PIA w/ Honda's..especially if u have to do the work outside..very tough to see the oil line on the dipstick in the sunlight...and if the bike is titled at all, the reading is different....I do love this bike but the engineer who designed how the oil is checked should be shot
Old 03-19-2012, 05:18 PM   #6 (permalink)
I use a 2x4 to prop up the bike when I check the oil. Works great!
I prefer dangerous freedom over peaceful slavery.
Ride your own ride, don't tell me how to ride mine.
shadow247 is offline   Reply With Quote
Old 03-19-2012, 05:37 PM   #7 (permalink)
On my 750 I usually sit on the bike so it is level and then reach over. Oil should be between the dipstick lines but does not have to be accurate. I use a small funnel and just pour in a bit and recheck.
In the old days there was no dip stick: just an inspection cap or a glass window and the only way to see the level was if the oil was black or open a drain plug and if none came out it was low and if some spilled out it was full.
G.
Old 03-19-2012, 06:56 PM   #8 (permalink)
I've been known to curse engineers on more than one occasion but this is pretty simple stuff here, whether your're changing or just checking the oil.
2008 750 Aero
MudholeMike is offline   Reply With Quote
Old 03-19-2012, 08:02 PM   #9 (permalink)
Swilly's Avatar
2 glugs.
When The Knock On The Door Said Alcohol, Tobacco, and Firearms, I Naturally Thought It Was A Delivery.
Swilly is offline   Reply With Quote
Old 03-20-2012, 10:44 AM   #10 (permalink)
Originally Posted by Swilly View Post
2 glugs.
Is that a technical term?
Texas Twitch is offline   Reply With Quote
