engine degreaser - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-19-2012, 03:38 PM   #1 (permalink)
kiki's Avatar
Question engine degreaser
can I use regular engine degreaser on my 600 vlx to clean her up...and what areas to avoid spraying??????
kiki is offline   Reply With Quote
Old 03-19-2012, 04:01 PM   #2 (permalink)
oblivion_twister's Avatar
I use simple green, let it soak for 10 minutes or more then hit it with the hose, what doesn't come off gets simple green again, soak, wipe with a rag, rinse and done. Engine degreasers can etch aluminum leaving it chalky looking.
oblivion_twister is offline   Reply With Quote
Old 03-19-2012, 05:21 PM   #3 (permalink)
+1 on the Simple Green. If you a cheap ******* like me then just mix up some Dawn or Palmolive, spray down a lukewarm motor with water, then hit it with the Dish soap, and rinse. What doesn't come clean will likely take a bit of elbow grease. I find that old dirty microfibers work great.
I prefer dangerous freedom over peaceful slavery.
Ride your own ride, don't tell me how to ride mine.
shadow247 is offline   Reply With Quote
