Possible Starter Relay Issues? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 9 (permalink) Old 03-19-2012, 11:52 PM Thread Starter
Howdy everyone. Im pretty new here.
I drive a 98 Honda Shadow Vlx 600. I have devloped a severe electrical issue.
When I switch my key to the on position all the lights come on as usual. BUT, when I press the start button the relay clicks irratically(almost a electrocution sound). When that happens all the power cuts out and then there is no power what so ever. If I wait a bit, the power slowly fades back on. But after that nothing happens when I press the start button(the power cuts out momentarily tho).
Voltages: With key off ~12.6v
With key on ~12.6v
With key on /w start button pressed ~ 7v
After start button is released ~All over(v)
I have never delt with an issue like this before. Am I spot on with the Starter Relay being the issue? Or are there other known causes for my symptoms?
I guess if it is the starter relay, is there a rebuild kit or would you just replace the whole relay?
Thanks in advance everyone looking for some suggestions to work on.
boostedchicken is offline
post #2 of 9 (permalink) Old 03-20-2012, 12:04 AM
I would say that your battery isn't up the job. Take it to a battery store and get it load tested.
jpr1968 is offline
post #3 of 9 (permalink) Old 03-20-2012, 12:08 AM
Earthling789's Avatar
^^^ Agree ^^^
Sounds like the right symptoms for a bad battery cell (or two)
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow
1999 CB750 NightHawk (son's ride)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
"I'm not behind you, I'm 21,565 miles in front of you, and about to lap you again!"
Earthling789 is offline
post #4 of 9 (permalink) Old 03-20-2012, 12:09 AM Thread Starter
I was first thinking the same. But then I was tinkering around with the relay and with the key in the on position, I can tap the bottem of the Starter Relay and it will make the lights go out. But maybe that is supposed to happen.
I will investigate more tomorrow.
post #5 of 9 (permalink) Old 03-20-2012, 12:11 AM Thread Starter
Originally Posted by Earthling789 View Post
^^^ Agree ^^^
This could very well be. I have had the bike for 5 years (holy smokes its been that long....) and have never replaced the battery.
post #6 of 9 (permalink) Old 03-20-2012, 08:48 AM
Clean and tighten your battery cable connections at both ends. even if they look clean rub them with a little sand paper. have the battery ground cable disconnected at the battery when doing this so you dont short the system out.
dgraves49 is offline
post #7 of 9 (permalink) Old 03-23-2012, 03:40 PM Thread Starter
Well you all were completly correct.
I talked to my bro who is an Interstate Batteries dealer, he said his old Carquest battery did the same deal.
I had an Interstate Cycle Tron 2 delivered to the house, assembled/charged it. Bam problem solved!
I was just confused because all my other batteries that have failed actually wouldn't hold a charge, new lesson for me I guess.
Cheers.
post #8 of 9 (permalink) Old 03-23-2012, 04:42 PM
Location: SW Georga Between Americus & Beuna Vista - Plains & Ellaville - Preston & Andersonville
I won`t say the battery was good or not...
However, when you changed out the suspect battery, you mightta cured the loose disconnection causing these symptoms...
Glad to hear you`re "on the Road Again"...
Ride Safe,
Dennis
"Captain D" is online now
post #9 of 9 (permalink) Old 03-23-2012, 08:30 PM
You should still investigate why the battery went bad in the first place. You may not beout of the woods just yet. You should check the charging system and wiring before riding too far. Just sayin'.
PainterD is offline
