1986 VT500 Fuel Reserve Switch Leaking - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-25-2012, 04:40 PM   #1 (permalink)
Default 1986 VT500 Fuel Reserve Switch Leaking
Hi,
It's finally warming up and I've had the bike out several times. I need to fix or replace the fuel reserve switch. It will leak right out through the switch after I shut the engine off and lean the bike over or when I turn the switch to OFF or RESERVE. It's not a slow drip, it's a fast leak. Do I need to replace the entire unit? It doesn't look like I'm supposed to be able to take it apart (except for the accelerator pump).
Thanks
1977 Kawasaki KZ1000LTD -------------------- 1986 Honda Shadow VT500
MidnightBlue is offline   Reply With Quote
Old 03-26-2012, 07:23 AM   #2 (permalink)
tubes_rock's Avatar
I've never really looked too closely at the one for the VT500. My wife has a Honda 450 from the same era and it's riveted together, so it has to be replaced as unit. I've seen other Hondas where the petcock is held together by screws and you can (and I have) repair those.
So I guess the short of it is:
Rivets = replace
Screws = repair
I've not tries drilling out the rivets and replace them with screws, but someone so dedicated could probably make that work.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 03-26-2012, 10:22 AM   #3 (permalink)
still_bluenoser's Avatar
Just replace it. I've drilled the riveted ones apart, tapped the holes and put them together, but rebuild parts are hard to find unless you dont mind blocking off the vacuum shut off portion, (not accelerator pump)
1983 vt500c
1979 cbx
still_bluenoser is offline   Reply With Quote
Old 03-26-2012, 10:33 AM   #4 (permalink)
My Buddy (with the Magna probem) has JB Weld on his petcock, it still leaks...
IF It were me, I`d replace the faulty one with a rebuildable petcock...
My $.02,
Dennis
`98 VT750 A.C.E.
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Old 03-26-2012, 10:45 AM   #5 (permalink)
Thanks. What's my best option for buying that assembly?
