chain adjust sticker - Honda Shadow Forums : Shadow Motorcycle Forum
Old 03-25-2012, 05:19 PM   #1 (permalink)
kiki's Avatar
Question chain adjust sticker
my 2002 600 vlx...has no chain adjustment sticker.....can someone take a pic of theres so i have an idea how many notices i have left before replacing chain....my notice is on 5 from end...and chain still needs adjusting.....look @ pic
kiki is offline   Reply With Quote
Old 03-25-2012, 05:30 PM   #2 (permalink)
I would not really go by those marks to determine when you should replace the chain. I switched to a 39 tooth rear sprocket on my 750 Spirit and my chain adjuster is now past the mark to replace because of the smaller sprocket.
If you have stuck links, rusty links, or any rollers that won't roll, then you should replace the chain. If the chain is properly adjusted (I use the 2 finger method on all my bike), and you can pull the chain off of the rear sprocket and see more than a 1/4 of the tooth it's time for a new chain. You should replace at least the rear sprocket at the same time.
I prefer dangerous freedom over peaceful slavery.
Ride your own ride, don't tell me how to ride mine.
shadow247 is offline   Reply With Quote
Old 03-25-2012, 05:38 PM   #3 (permalink)
kiki's Avatar
everything is stock....chain is fine, everything looks good.....just need to adjust chain and was wondering how far was too far...since i dont have sticker....
Old 03-25-2012, 06:30 PM   #4 (permalink)
craig s.'s Avatar
duplicate post,cant delete
2003 vlx 600
Freedom to ride is brought to us by the men and women who gave their lives serving our country and those who continue to serve.THANK YOU!
http://www.youtube.com/watch?v=QPHJFEcrHQ4
http://www.youtube.com/watch?v=B4h7AQArOCU
craig s. is offline   Reply With Quote
Old 03-25-2012, 06:31 PM   #5 (permalink)
craig s.'s Avatar
your's
mine :
hope this helps.it looks like yours is on the 5th notch which is still in the green..you should be good to go.
2003 vlx 600
Old 03-25-2012, 06:34 PM   #6 (permalink)
kiki's Avatar
blurry, but thanks...graig!!!! good enough to see.....................
Old 03-25-2012, 09:40 PM   #7 (permalink)
I still wouldn't worry about the marks. You should do the link pull test. Adjust the chain tension to the factory specs, pull on a link on the rear, and see how much tooth you can see.
