Carb parts - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-02-2012, 08:16 PM   #1 (permalink)
Send a message via MSN to sikewrdpryznr Send a message via Yahoo to sikewrdpryznr
Default Carb parts
I'm wondering where you guys are finding your carb parts? I'm sure someone out there has to have had to buy some and I'm looking for a cheap one lol. Can't find it on ebay, and all the parts websites either say obsolete, not available, or $105.81 lol. For a stupid little piece of plastic called the vacuum piston. It's going in a 1986 Honda Shadow VT700C.
Anyone that has any information on finding a cheap new one or even a used one in good condition would be very much appreciated. I don't mind as long as it's not like mine and has a cracked diaphram.
Or with it being obsolete on most sites, are there any parts that are interchangeable with the model years? Like will one from a 83-87 work just the same? I don't want to blow a benjamin if I don't have to lol.
1986 Honda Shadow VT700C, First bike
sikewrdpryznr is offline   Reply With Quote
Old 04-02-2012, 08:58 PM   #2 (permalink)
vccomputerguy's Avatar
This thread I had might help you: Vacuum Piston Question
I ended up repairing my vacuum piston diaphragm. Good luck!
VCcomputerguy
83 VT750
vccomputerguy is offline   Reply With Quote
Old 04-02-2012, 09:14 PM   #3 (permalink)
Well it seems I"m going to have to take it apart again anyways. I did use some rtv on the small rips that the one had. Now it doesn't hesitate in the throttle but it seems to be running really rich, as it's backfiring. Anyone know of a fix for this or a main culprit? It wasn't backfiring before I took it apart and "fixed" the diaphram, so I'm thinking maybe the fuel bowl or something is messed up. I tried adjusting the pilot screws and it's still backfiring throughout the throttle now.
Old 04-05-2012, 12:41 PM   #4 (permalink)
Alright, well I checked the spark plugs and they seemed to be a little black and sooty. So I replaced all of them, and the old ones didn't look gapped right. Checked their gap and they barely fit on the gapper ring that I got from O'Reilly's so they were gapped to small.
The ones I replaced them with I made sure and gapped them all to 0.9mm and it seemed to fix the backfiring problem, but now I'm back to hesitation in the throttle. This morning I took it back apart because I thought I'd check the float levels. One was at 8mm and the other was at like 7.1mm. I put them both to 7.5mm like the manual says, but I'm not going to put it back together until I make sure and check for some more information on here or just online.
Anyone know if the float levels would make it act like it's bogging down when I go more than about 1/4 throttle? Also, it seems like the patch job that we did on the diaphram was holding up fairly well, but the one we didn't mess with seems to not be sliding easily in the slot that it goes into, is there anything you guys would recommend that I lubricate that with? Or should I just leave it alone?
Old 04-05-2012, 07:49 PM   #5 (permalink)
interesting source for cheap? riplacement diaphrams
Keihin 72mm diameter diaphragm Honda VT CBR Hurricane Installation
atrent is offline   Reply With Quote
Old 04-06-2012, 12:22 AM   #6 (permalink)
Thanks a lot for that link. I'll be ordering me a couple of those in the next couple of days. I haven't put the carb back on yet and tomorrow I will measure to make sure I get the right one. Again, thanks for that, I would have never thought about just replacing the diaphram on it
Old 04-06-2012, 07:30 AM   #7 (permalink)
no problem let us know how you make out
Old 04-06-2012, 08:15 AM   #8 (permalink)
make sure ur testing with the air filter cover screwd down tight and ur air box drip tube capped or this bike will not rev up past 1/4 throttle
98' 1100 Aero
95' VLX
80' CX500
CavemanBen is offline   Reply With Quote
Old 04-06-2012, 09:00 AM   #9 (permalink)
also keep in mind diagnosing carbs is directly related to throttle position. at 1/4 if both cylenders are firing asume your pilots are ok (id set them at 3 1/4 turns out) and look towards your slow jets. make sure there is no deposits on your jet needles and use gasoline to clean the cv pistons (hopefully this will alow them to side better). also the path from the needle jet spiders off inside the carbs, make sure you blow these all out with compressed air. it took me 8 attempts to get mine cleanned out right last time.
98' 1100 Aero
95' VLX
80' CX500
Old 04-06-2012, 10:51 AM   #10 (permalink)
Well after reading some stuff online yesterday, I realized that when I started it up the last time, the airbox wasn't attached, we still had it semi-torn down as we were checking stuff still. But I don't remember if the air box drip is capped or not. Doesn't that defeat the purpose of a drip tube if you cap it off?
