You have to start with the basics.
Check the plugs, wet or dry Check for spark. Check for fuel at the carbs (use the drains to see if the bowls are full) Check compression Have you visited the "Sticky" on what to do if your bike will not start? |
#4 (permalink) |
Another thing to check is battery voltage if my is even a little low it side the same thing, charge her up and fires first try
================================= Swyped from my Warm Gingerbread Evo 4D (smellaphone) Using the Motorcycle app
84 VT500 ![]() 86 VT700
#5 (permalink) |
this engine will only run if the intake is just rite and it wouldn't hurt to have the exhaust compleetly on. a dry foam filter or a loose connection in the snorkle can stop it from running. look at the what to do when my bike won't start sticky. change all 4 plugs and check the compresion would be my first step check spark then charge battery. bike needs the choke to start and no throttle usually. if you have fuel in the bowels and compression and spark you should get something. if not then a carb cleaning may be in order. this is the short list. are you getting any sputtering?
![]() 1983 VT500C & 2003 Kawasaki Vulcan Drifter 800 |
