I just did a calculation on carbjet.com and it gives me a rejet of 120 and slow jet of 42 for southern California - this is with no or mild mods. Manual says 115/40. I only ask because I've been running lean, bike smells of gas and exhaust smell heavy. I just did plug change, air filter change (k&n) oil change, coolant change and got to carbs but decided I would see if all the other changes help before I tear down carbs. Now since I have k&n filter and not sure if exhaust is aftermarket should I just rejet if I tear down carbs? And will that hurt if bike doesn't need it?
#3 (permalink) |
Let see, the front plugs one was black with either gas or oil on it, the other front I think was black with gas on it, the backs were black no gas I think. The we're all way out of gap. I'm thinking to run plugs and see what they look like after. Also really considering that seafoam stuff in gas and oil because of the how dirty oil and plugs were. Not to Into putting stuff in my oil may just do another change instead. See how she runs for a while then do carbs.
#4 (permalink) | |
![]() Keep the rubber side down ... unless of course you have a rubber head! My Road to Rod, 4° Advance Timing Mod, Tubeless Spokes, Walk Around Aced It ACE Service Manual: https://dl.dropbox.com/u/106488173/ACE%20Manual.pdf |
#7 (permalink) |
Your right sorry, running rich not lean. And the plugs that were way out of gap were the old ones not new ones. New are gap to spec. K&N air filter is a lightly oiled from factory filter and I don't think they say to oil it's almost like a stock replacement. The bike seems to start run well but really haven't ridden since I bought because I wanted to service. I will take out run it for awhile to see how it does, check plugs and see how they look. If running rich I will have to pull the carbs unless some knows other solutions. Thank.
#8 (permalink) |
If you are still running rich with stock pipes, jetting AND a K&N filter (which should have a mild leaning effect) the most likely culprit left is float level.
But first check your spark to see that you have a nice, fat blue arc across the electrodes. 'Cause there are only three things that will cause a rich condition: too little air entering, too little spark (or spark at the wrong time, unlikely in your case), or too much gas. |
#9 (permalink) | |
