So this morning (another coldish one here in Maine) as the bike was warming up I noticed that smoke from the exhaust seemed to be mostly coming from the front pipe (in that as it warmed, the smoke from the rear stopped well before the front). First question here is, does that mean too rick or too lean (I'm guessing rich?), and the second question is which way do I adjust the a/f screw (if thats the solution) to solve that, OR does it not matter?
Thanks!
2002 Honda Shadow VT750DC
Was it "smoke" or condensation? Smoke is black or blue or grey. Condensation is white.
![]() ![]() 1996 VT1100C 1999 GL1500CF Bell: Kara WJR#78 "A government big enough to give you everything you want, is big enough to take away everything you have." - Thomas Jefferson |
#3 (permalink) |
Condensation, that was the word I was looking for, but yes, it was condensation. I figured it might be a tell that the front cylinder takes longer to warm up for whatever reason.
#4 (permalink) |
That's because the front pipe is longer and yes, takes longer to warm up.
#5 (permalink) | |
Well, that makes a remarkable amount of sense, clearly I didn't look for the easy solution, thanks!
#6 (permalink) | |
I live by this: Occam's razor - Wikipedia, the free encyclopedia
#7 (permalink) | |
AS far as the AF mix. Leave it alone until you aquire a Service Manual. Lots of things affect AF mixture it idle and you NEVER adjust the AF mixture screws or jets "because" of an issue at cold start-up. AF mixture is only diagnosed and adjusted with a fully warmed up motor. A Cold motor is a time where you want a VERY rich mixture. And is adjusted via the CHOKE. If you are lean at start-up, A choke is out of adjustment. Yes the mixture requirements can be different between the cylinders, especially in a Vtwin. The cylinder in front tends to run cooler then the one in the rear, AF mixture is used to balance the combustion temps. This is not as big a deal with Waterpumpers, but even some Shadows run a rich rear jug AF screw is adjusted in to lean out to richen. Unbalance AF mixture requirements can also be due to engine condition. UNsynchronized carbs can also appear as Lean/Rich in one cylinder.
