Yes, I have a service manual and yes, I read English. I used to turn wrenches, but as the years have gone by, I would prefer not.
Scooter has 6000 miles on it and is 6 years old, so probably orginal plugs. I have had the fuel tank part way off, but initially could not get the vent line off - probably didn't try hard enough. Easy to get fuel line off. Is there anything else attached to the fuel tank? I have read about the special wrenches for the plugs, so I know that. Do I have to use OEM plugs or are their suitable other brands? With the tank off, is it a straight forward job to change plugs, or are there other issues which may be a challange for someone with fat fingers and a lot of bad luck? Stealer service dept. wants $100 for the job! .
![]() Current ride: 2008 Goldwing with Roadsmith Trike Conversion Below, gone to a new home at Bolling AFB, Washington, DC 2011 Shadow Aero VT750C |
#3 (permalink) |
With 6000 miles your plugs are likely still good but might as well take them out. I would do so before buying new ones.
Tank has bolt in front and bolt behind, fuel line and vent tube. My vent tube pops off simply but I don't think you need to remove tank to remove plugs. Use a little dielectric grease on the spark plug porcelain when installing and the caps will slip off easily next time. I use OEM NGK DPR7EA-9 and they do a good job. G |
#4 (permalink) |
You get a box spanner in the toolkit, but I find any double ended box spanner will do then I fit a socket over the 'other' end and use my socket wrench to change the plugs, I can even use my torque wrench to tighten them to the recommended 10 ft lbs.
John.
#5 (permalink) |
What NKG plug is used in my scooter?
#7 (permalink) |
You shouldn't need to remove the tank to change spark plugs. The size is on the plugs you take out, just look at the plugs!
I remove mine every year to make sure they're running at the correct color, which tells you how your bike is tuned.
#8 (permalink) |
You will also need a 18mm THIN wall DEEP socket, or MC sprk plug tool. Tank stay in place, and there are 4, yes four, spark plugs at the end of the 4 heavy wires that exit from under the tank and end at the sides of the heads.
#10 (permalink) | |
Well, since I had to go through what I thought was going to be aggravation of pulling them, I decided to change them anyway. Put in DPR8EA-9 . Well, should have taken G's advice. Exhaust side looked brand new. Intake side slightly tan, though both had open gaps. Since I had bought the plugs already, I went ahead and put them in, so at least I know when they are going in, so when I go back to OEM exhaust, I'll be able to "read" proper mixture. Thanks for advice. Appreciate it.
