#32 (permalink) |
The manual says there are crank/ignition pulse generators and camshaft pulse generators. But it does not say why or what they control... The ignition module gives the signal to the both connectors but I haven't found what gives the ICM its input yet. Both connections have power (Black/white wire) with the kill switch on.
The blue wire from the connector tee's of and goes to the Spark controller 1 and fuel cutoff relay. I'm tired and may be over thinking it at this point but if the fuel pump runs, being controlled by the fuel pump relay, and the relay switches on by the blue wire, getting its signal from the ICM-tying into the connector for the front coil, then it should be working.... Dang almost confused myself on that one.. Until tomorrow. |
#34 (permalink) | |
Fault:: No spark to left cylinder... spark ok to right cylinder... what you know..all spark plugs are new..right coil works, right HT lead works right plug cap works.. What you don't know Left coil?? left HT lead??? left plug cap?? What you have done... Tersted left coil by swapping to right...coil works... What haven't you done ....tested left HT leads or plug caps..or have you? John.
#35 (permalink) |
LLLL, I`m confused now...
I ain`t no mechanic, I just work on everybodys Bike, fer those that can`t afford a mechanic... Good Luck Dartmech, Dennis
`98 VT750 A.C.E. Motorcycle Rider Rights Activist www.mrf.org www.MSF-USA.org www.ABATEGA.org ABATE member 36yrs. http://www.ama-cycle.org/ Elect "Motorcycle friendly" government officials ONLY! |
#36 (permalink) |
I swapped the function of the coils/wires/caps. I switched the red/white connectors, then the spark plug wire (HT wire) sets to each cylinder. Think completely removing the coils and wire sets and swapping them to the other cylinders. Everything related to the left cylinder(dead) would fire off the right perfectly. The Right cylinder components stopped working on the left.
I am confident that the Ignition system, as far as the coil/wire/caps/plugs are concerned, is operational because as long as either set is hooked up to fire the right cylinder, they do. The problem is the BLUE wire in the RED connector for the left cylinder ignition signal. I'm in the process now of tracing down the pulse generator connectors to ohm but I haven't located all the connectors I need yet. Does one pulse generator control one cylinder? That seems odd to have an independent ignition system. |
#37 (permalink) | |
I've written that badly the heads are mounted one at the top and one at the bottom of the wheel.. John.
Beauty is only skin deep but ugly goes right to the bone. Last edited by John Hopkins; 04-18-2012 at 12:16 PM. |
#38 (permalink) |
I see what your saying and understand the principle of the generators. Your saying the pulse generator is less likely to fail. It's more likely the wiring has broken or become open in the circuit somewhere. Correct?
I'm headed out now to get back at it. Hopefully I'll have more information when I return. Thanks. |
#39 (permalink) |
Ohm checks passed on EVERYTHING... The cam and two crank pulse generators show pulsing with a test light.
With the one cylinder running the signal wire to the coils pulses, the signal wire on the dead cylinder is steady on. There is continuity from the red plug to the spark box. All signs are pointing to the big Spark box next to the battery being defective/ not distributing the signal to the forward coil, just staying on. |
