Bike stalled today - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-14-2012, 09:19 PM   #1 (permalink)
Kitulu's Avatar
Default Bike stalled today
It has stalled out once or twice over the last week or so. The odd thing is that it did it while slowing down for a turn or to come to a stop while I was shifting from 4th to 3rd, or 3rd to 2nd...It went like this: Pull in clutch while rolling off the throttle, step down on shifter, let clutch out while rolling on throttle, bike has stalled.
In each case I was able to pull the clutch back in and restart the bike with no issues.
I am running with a Dynojet Stage 2 kit, c-clip on the third notch, fuel/air screw about 2 and 3/4 turns out, Thunder Air Kit, and Hard Krome K2 pipes.
FWIW, the bike did NOT do this when I first rejetted, this only started up recently.
Any ideas?
Kitulu is offline   Reply With Quote
Old 04-15-2012, 07:12 AM   #2 (permalink)
John Hopkins's Avatar
What bike and how old is it...
when you rejetted did you do it yourself..
while you had the carbs out did you fit new repair kits or just change the jets..
when you changed the fuel filter was it dirty.
John.
Old 04-16-2012, 07:11 AM   #3 (permalink)
Kitulu's Avatar
The bike is a 2005 Aero 750 with around 5000 miles on the clock. I rejetted myself. I did not replace anything else as the carb was clean. I did not think that the fuel filter would need changing already , so I may change that out to eliminate it as the problem.
Sent from my DROID2 GLOBAL using Motorcycle.com App
Old 04-16-2012, 08:19 AM   #4 (permalink)
Scrapdog2grand's Avatar
any sudden changes in air temps over the last couple weeks?
when fully warmed up with a hot engine, when you snap the throttle do the the rpm's drop before they come back up to normal idle?
may just need to readjust the idle mixture.
1999 VLX
1998 SA750
2003 SA750
Old 04-16-2012, 09:02 AM   #5 (permalink)
Throttle set screw could be adjusted too low.
1997 Honda Shadow VT1100C1 Spirit -- Too much work to list
tcanthonyii is offline   Reply With Quote
Old 04-16-2012, 09:29 AM   #6 (permalink)
Super Moderator
old dad's Avatar
this^
I let my brother ride my vlx, he thought it idled too high, adjusted it, next day I stalled too as I was slowing to stop..Just up the idle a bit and see if this resolves it. It did for me.
2006 vlx
