Rear turn signal staying on like running light- any ideas? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-15-2012, 09:31 PM   #1 (permalink)
Default Rear turn signal staying on like running light- any ideas?
I'm having a hell of a hard time with the wiring on this bike. I've just noticed that my rear left signal is staying on like a running light. Any thoughts as to what this could be? All other lights work as they are supposed to. The left side (front/rear) are flashing very slow.
1983750C is offline   Reply With Quote
Old 04-15-2012, 09:38 PM   #2 (permalink)
triplblk91conv's Avatar
Is that bulb in backwards? I had that happen on a car taillight once.
Dan
1985 Honda Shadow VT700C Black
1983 Honda Shadow VT750C Black
2013 Chevy Avalanche Black Diamond
2008 Pontiac Torrent GXP AWD Black
1991 Corvette Convertible Black
triplblk91conv is offline   Reply With Quote
Old 04-15-2012, 09:39 PM   #3 (permalink)
Nope.. the bulb is in correct.
Old 04-15-2012, 10:03 PM   #4 (permalink)
Default Do you have a multimeter handy?
Check for continuity from negative battery post to turn signal casing (ground) to verify. Faulty connections from corrosion, bad terminals, broken wire, etc. can cause weird symptoms.
eots is offline   Reply With Quote
